John M
leak??
leak??
"I Can't Drive 55!! Last edited by jmarenas; 06-08-2005 at 09:44 AM.. |
Check your cam oil lines, mine were leaking a bit, part $30 andabout 1 hours of labor from a guy that had never worked on a Porsche.
The line is easy to spot, it hides behind your ac compressor just above the chain cover. Oh wait! You said driver side! So it would be the one behind the distributor. For this one (if it is leaking) you would have to remove the distributor. (add 20 minutes of labor)
85 911 SuperSport No more looking! The jewel is mine! 89 Jeep Wrangler A jewel in the rough 2000 Grand Cherokee Family Wagon with Jewels on board |
The leak could come from the cam housing seal or the hi-pressure seal on the bolt.
I tightened down on the bolts mine to stop the leak from the cam housing seal. That did not stop the leak. I also had to replace the hi-pressure seal on each bolt. ---- anthony |
Both my cam seals are leaking. I thought the engine had to be removed to replace them and was planning on taking care of them when I get a top end rebuild done this fall. If its not that big of deal I'd rather fix the seals now and stop dripping oil all over the headers...and garage.
1987 911 Guards Red Targa, nearing 200,000 miles, lowered, 7's & 8's, 964 grind cams from John Dougherty, A.P.E. Mass Flow Sensor with chip to match, cat bypass, strut brace, dual out muffler. Will consider newer model in 8 years when I turn 75 and then maybe not. 2012 BMW 528i (wife's) 2007 Toyota FJ (rain and off road days) |
