-   -   bouncing tach (http://forums.pelicanparts.com/porsche-911-technical-forum/166159-bouncing-tach.html)
Padrino 06-03-2004 10:58 PM
bouncing tach
Dwell's dead on 38 degree on my 2.2S. The tach has taken to bouncing of late. Will jump up to 8k when doing around 4k. All over the place. Any ideas? Car has permatune blue with 6 pins, running webers. Was fine forever and just in the last weeks taken a mind of its own.
Ken
D Hanson 06-03-2004 11:31 PM
I just like to think my ebgine revs so quickly that the tach has a hard time keeping up. It does seem this way in the sweet spot.
rotorhead 06-04-2004 01:28 AM
I had the same problem on my 88 930, check your voltage regulator by measuring the voltage across the battery terminals with the engine running. It should read read around 14v if it is higher than this then replace the regulator and it should fix the tacho bouncing.
Jim Sims 06-04-2004 06:28 AM
On the early cars this is sometimes traced to the points; check your timing and dwell. Jim
kach22i 06-04-2004 06:44 AM
Ditto that, check/replace the points- I had a similar problem, but not the same.
I was told that the RPM's are taken off the points, not an actual reading of the engine. If the tack acts up it's sometimes the points.
Padrino 06-04-2004 08:47 AM
voltage is perfect at 14v. just had new gen/reg installed.
dwell is dead on at 38 degrees.
next????
Ken
next????
Ken
RoninLB 06-04-2004 10:52 AM
Originally posted by Padrino
next????
- change the good points to another good set.
- check 2 into 1 tach connector in harness, on left side of engine comp
- borrow a friend's good coil and CD to confirm yours is ok
- tachs have an internal spring that wears out.
- borrow a friend's tach to see if problem stays or leaves.
I assume the problem was there before you changed alternator. A presumably good alt and reg can cause a tach problem. Don't forget to report your success.. eventually.
markwemple 06-04-2004 11:05 AM
You would be surprised what a faulty ground strap can do. I would check all of them.
Randy Webb 06-04-2004 02:41 PM
sometimes caused by a CDI box
as well as the points, coil, V. reg., or ground straps...
braddb_82SC 06-04-2004 03:06 PM
Check your spark plug wires. Last time this happend to me I traced the problem to corrosion where a connector contacted a plug. I pulled the connector off the plug and cleaned it with some sand paper. The bouncing tach settled back down.
Another time it was due to a bad alternator or voltage regulator (integrated on my '82 SC). 24 hours after the onset of tach bounce the car stranded me on the side of the road due lack of electrical power. My battery was no longer charging. A new alternator solved the problem.
-Brad
kach22i 06-05-2004 03:04 AM
Someone told me that there is a ceramic/porcelin ground connection that sometimes cracks causing many funny problems. It's located in front of the driver on the otherside of the firewall.
They said:
I had an electrical problem couldn't figure out what was causing it. There is a wiring harness on the fender wall directly in front of the driver. The ceramic posts had cracked and was causing a short.
Note: Seems like even good points aren't good enough for long on my car- going pointless by the end of summer.
