Black box-curious
Thanks for the great forum !
i Have a very intermittent hot start problem on my 88 row carrera,A kind memeber suggested replacing the dme relay under the drivers seat.
Had a look today and found a magazine size black box with multipin connector and a fuse on it.I then looked under the passenger seat and found a silver box with a large rectangular connector with a small black relay in front of it-is this the dme relay and the main control box,if so what is the other box under the drvers seat?
cheers
p.s have ordered 101 projects -so hopefully no more dumb questions !
88 targa gone but not forgotten.
91 c4 coupe
Old 06-06-2004, 03:50 PM
Eric Coffey's Avatar
Yes, assuming right-hand drive, the box under the passenger seat is the DME, and the black relay next to it is the DME/fuel pump relay. I'd guess the "magazine" box under the driver's seat is maybe a stereo amplifier?
Old 06-06-2004, 03:59 PM
Cheers Eric ,Guess i can bin it as ive put a new cdplayer in .
91 c4 coupe
Old 06-06-2004, 04:04 PM
Just make sure it isn't powering your existing speakers before you pull it. If you just hooked up a set of RCA cables (rather than directly wiring the speakers to the new deck) chances are that you are still using the amp.
Old 06-06-2004, 04:09 PM
No problem will pull the plugs out and see if the stereo still works
91 c4 coupe
Old 06-06-2004, 04:33 PM
