Starting problems
If I drive the car, then park and go to start it a few hours later, it won't start right away. I have to try 4-5 times. Then when it does start it sounds like a lawnmower (putput-putput) for a few seconds.
If it has been sitting for a while or a few minutes it starts instantly. So it seems to have problems when it is just warm, not hot and not cold. Any ideas? Ed |
- fuel pump check valve
- accumluator get a fuel psi test gauge set from Pelican to diagnosis just about any CIS prob. |
I second what Ron said.
Is that the Bosch CIS tester?
Is there anything I can check before I get the tester?
if it immediately starts then it's the check valve or accumulator. Get the gauges anyway for the next time. |
Sorry, I am new at 911s and this is my first attempt at working on one. can you please explain where the air sensor plate is? Do I do this procedure when the car is acting up?
Thanks |
Also on p95 of Waynes 101 Projects book is "Tuning and Adjusting CIS Fuel Injection". http://forums.pelicanparts.com/uploa...1086390043.jpg |
| All times are GMT -8. The time now is 11:46 PM. |
