Need 3.6 Conversion Help - A/C
The 3.6 is in my 81SC and running great. Now for the A/C.
With the 3.6 I need to use a later compressor than I had for the SC so i bought one off of a '93 RS America along with the needed fittings. I plan on converting to R132. Hers's the question - What else do I need to get the A/C back up and running? I know I should replace the Drier, do I need a different one or can I just buy a new one from Pelican for the 81 SC. What else is involved? I know nothing about A/C systems - You probably figured that out. Thanks |
Replace the expansion valve and ALL the orings. The hoses are your call. Also you're changing to R-134 not R-132
Do you have any picts of the conversion? |
| All times are GMT -8. The time now is 06:52 PM. |
