-   -   Restoring Brake Calipers (http://forums.pelicanparts.com/porsche-911-technical-forum/166412-restoring-brake-calipers.html)
JRISER 06-05-2004 04:07 PM
Is there any substance you can apply to calipers to preserve that just-bead-blasted-look and will stand up to the heat? Will bead blasting make them look like they were when they were new? Does anyone have any experience with this or restoring the engine fan and housing? I really do not want to powder coat anything.:)
BTW, I have already looked at the posts that outline painting and powder coating.
Thanks for everyone's continued help and encouragement!!!
Early_S_Man 06-05-2004 06:40 PM
John,
The original finish was cadmium plating on the cast iron, so ... no, bead blasting won't restore it, but it would be a good prep prior to getting them yellow zinc plated -- the current replacement finish that looks similar to the OEM cad plating.
911pcars 06-05-2004 07:55 PM
Painting calipers is an accepted practice among both porschefiles and ricers. Painting also avoids heat-induced plating that would normally cook the seals. Eastwood sells a yellow look-alike zinc-colored spray paint. That should mimic the look you want without having to disassemble and replate them. But I would mask the non-caliper parts (bleeder screws, through bolts, crossover pipe, mounting bolts and such, and of course rotor) to avoid the "if it doesn't move, paint it" military slogan. However, I don't know if the paint will hold up to the rigors of Porsche-type braking maneuvers.
Sherwood
http://members.rennlist.org/911pcars
JRISER 06-05-2004 09:56 PM
Thanks for the suggestions.
If the original finish was a cadnium plating, then wouldn't it be okay to plate them again with yellow zinc plating? I'm just curious as to why they would overheat.
911pcars 06-06-2004 03:17 AM
Don't get me wrong. You can replate the calipers. However, the process requires complete disassembly of the calipers. Something you may or may not want to do.
Sherwood
911nut 06-06-2004 04:59 AM
John, most people recommend not disassembling the calipers because they tend to leak when you re-assemble them and the seals that go between the spacers and the halves are hard to get.
I dis-assembled one of mine during the course of rebuilding this past winter and it didn't leak when I put it back together. I used the original seals in the re-assembly.
Maybe I got lucky :D
Superman 06-06-2004 08:13 AM
Ummm, I've been disassembling calipers and replacing seals for many years and no, they don't leak. Sure, if pistons are scored they can leak, but replacement pistons are available. There is no seal between the halves according to my understanding, but nobody takes them that far apart. At least I wouldn't. They probably would leak.
You'd have to protect the cylinder surfaces while they're bathed in the zinc stuff. Not sure how that would work. Painting is the most common. Laquer, I think.
911nut 06-06-2004 11:22 AM
Super, I'm talking about splitting the calipers halves.
Early_S_Man 06-06-2004 12:20 PM
The seals between the caliper halves are not O-rings ... they are just small versions of the Ate seal used in the caliper bore around the piston. They don't leak when replaced, unless the caliper was leaking beforehand due to massive internal corrosion from neglected brake fluid ... that is an urban legend of gigantic proportions!!! The factory sells the seals, as do VW and Mercedes dealers. The Clymer <b><i>Porsche 912 Handbook</b></i> has had the replacement procedure in it for over 30 years, now, using Porsche factory illustrations and pics. The biggest difficulty in splitting the caliper halves is that some use a very odd Ribe fastener that many assume is Torx, which it isn't ... and the bolt is destroyed by the Torx bit, rendering the caliper a piece of scrap!
Superman 06-06-2004 12:42 PM
Well I guess I don't know everything after all. I thought the caliper halves just fit perfectly together.
I've got a pair of Carrera calipers I've been meaning to refresh, so perhaps I will paint them. Or zinc coat. How are the cylinder surfaces protected during the zinc coating procedure?
Early_S_Man 06-06-2004 01:15 PM
Supe,
When I had some calipers replated with cadmium back in the '80s ... I didn't protect the bores, since they were originally cadmium-plated, too! No problems after the rebuild using the VW Type III caliper seals, either!
Here is an early parts diagram showing the split calipers, and the replacement caliper half seals, too ...
http://www.pelicanparts.com/911/911_...969/brakes.jpg
JRISER 06-06-2004 02:43 PM
Many thanks to everyone for the info. I am getting an education here that will help me make good solid decisions when restoring my calipers. Keep posting!
