-   -   Where to get my 911 weighed (http://forums.pelicanparts.com/porsche-911-technical-forum/166471-where-get-my-911-weighed.html)
smross 06-06-2004 08:24 AM
I've read many posts about getting cars weighed but where does one actually get this done?
magic930 06-06-2004 08:27 AM
At the dump or at a highway truck weighstation.
Bob's Flat-Six 06-06-2004 08:29 AM
Look in your local yellow pages for certified weight scales,
used for weighing heavy trucks loads.
You could also try a local scrap metal yard or landfill they usually have scales for weighing the trucks.
SmileWavy
Zeke 06-06-2004 08:41 AM
What they said. However, when at the track for OPC races, Chuck Moreland told me that I might have been able to persuade the tech guys to let me drive my car across the scales if they weren't busy. I didn't do it, should have. I would have gotten the corner weights had I done it.
Bob's Flat-Six 06-06-2004 08:58 AM
Highway truck weight stations ( here in Calif. anyway) weigh the axel's on the trucks independently @ 3mph, So if your over weight on say your front axel a red light will come as your passing through, And then you hear a voice from the heavens telling you to pull over. The light can come on for a number of things besides over loads.
Not my favorite scales SmileWavy
dad911 06-06-2004 09:25 AM
Stone yards, mason supplies, and larger landscape supply yards all have basic drive-on scales that would tell you the total weight of your car. However, some porsche mechanics 'corner weigh' the car as part of a wheel alignment. They have a scale under each wheel, and can adjust 'corner balance'.
Randy Webb 06-06-2004 11:39 AM
What's important is to find out how accurate the scales are. Resolution of the display is NOT accuracy. Also, ask how often they check the accuracy.
In Oregon, the free log truck scales are checked frequently by the state and are set to within 20 lbs. I always use the same one and try to hit it on days with similar temperatures and when it is in the shade (since many wt. measuring devices are temperaure sensitive).
