| Registered Join Date: Oct 2003 Location: Michigan
				 |  Holy Cr@#!! Its lower
			Hey guys. just got done with the first attempt at lowering the SC. Except for the p/s ride height bolt that wouldn't budge, it was pretty straightforward. I know I need to do some more adjustments, but it sure looks tough like this. I set my plates in the middle so that I should be able to dial her up a bit tomorrow night. 23.5 right now. I think 24 will be just about right. Thanks to all those that helped me from previous posts.   Wayne
				__________________ 1981 911SC ROW SOLD - JULY 2015 Pacific Blue Wayne | ||
|  06-06-2004, 05:52 PM |
| Registered |
			Looks good I would leave it as is
				__________________ 72T RS look 96 993 | ||
|  06-06-2004, 05:54 PM |
| Registered Join Date: Oct 2003 Location: Dayton, Ohio
			yep shes LOW alright!
				__________________ When I see something horrible, I push the gas pedal down...... because I KNOW at that point eveyone else is lifting..... "Quote from GrandPrix" | ||
			Forgot a before pic.  I can barely fit my index finger between the tire and fender lip is the reason i want to raise it a little. Seems a little close to be safe. Thanks for the comments.
|  06-06-2004, 06:14 PM |
| Me like track days Join Date: Sep 2003 Location: Kirkland, WA
			Back is a bit too low vs. front - lower the front a bit & grit your teeth ;-) or raise the rear a bit Craig @RS REALLY low - full track setup yikes on the street
				__________________ - Craig 3.4L, SC heads, 964 cams, B&B headers, K27 HF ZC turbo, Ruf IC. WUR & RPM switch, IA fuel head, Zork, G50/50 5 speed. 438 RWHP / 413 RWTQ - "930 is the wild slut you sleep with who tries to kill you every time you "get it on" - Quote by Gabe Movie: 930 on the dyno | ||
|  06-06-2004, 06:27 PM |
| What? |
			It looks much better!
				__________________ Tom J. 911SC Cab SCWDP CaymanS | ||
|  06-06-2004, 06:28 PM |
| Registered |
			You live in Michigan........what were you thinking? We have the worst roads, oh what the heck, it looks great. Good luck, and may all chuck holes move out of your way.
				__________________ 1977 911S Targa 2.7L (CIS) Silver/Black 2012 Infiniti G37X Coupe (AWD) 3.7L Black on Black 1989 modified Scat II HP Hovercraft George, Architect | ||
|  06-06-2004, 07:25 PM |
| Registered Join Date: Aug 2001 Location: SoBay, SoCal
			That's 23.5"?  Looks higher than that.  Don't get me wrong, it's definitely an improvement, but it's not too low.  I agree w/ Craig911--It can still go a little lower in front. Mine is 0.25" below Euro spec all 4 corners. Mike '86   | ||
|  06-06-2004, 09:47 PM |
| Registered Join Date: Nov 2001 Location: a few miles east of USA
				 | Quote:
   looks like it could be 23.5 to me.
				__________________ Rich  '86 coupe "there you are" | ||
|  06-06-2004, 09:57 PM |
| Registered Join Date: Apr 2002 Location: Santa Clara, CA
			Wayne, it sure looks good at that rear height.  But you have very little suspension travel left. The lowest I would go for a street car with standard spindle height is 24.5 / 25 assuming stock diameter tires and struts (even this is a stretch) Lower than this and you are hurting the front geometry pretty badly. And you'll be announcing your arrival on steep driveways.
				__________________ Chuck Moreland - elephantracing.com - vonnen.com | ||
|  06-06-2004, 10:04 PM |
| Registered | Quote:
|  06-06-2004, 10:09 PM |
			i have the figures chuck quoted and it looks about right - does nothing for your steering though.
|  06-07-2004, 04:43 AM |
| John M |  LOOOOWWW
			Here is a pic of my LOW rider, I live in Michigan and what a challenge to out drive and dodge the pot holes in our wonderful state.  Have been lucky thus far........
				__________________ "I Can't Drive 55!! | ||
|  06-07-2004, 05:17 AM |
| Registered Join Date: Jan 2002 Location: Birmingham, AL
			If your suspension is close to stock, it looks a little too low in the rear to me.  I lowered mine for the first time wearing a set of 17" cup wheels on a stock SC to what looks like the same height and had rubbing issues.  Couldn't get enough negative camber to get rid of it, so I raised the car half inch in the rear and it fixed the problem.  Looks cool though!
				__________________ Brian Starr Alabama Region PCA 1983 911SC/Rebodied as 993 w 3.6 1995 911 C2 (Sold) | ||
|  06-07-2004, 07:52 AM |
| Registered |
				Re: LOOOOWWW
 I went to a wedding there, beautiful.
|  06-07-2004, 08:31 AM |
| Registered |
			Ready for the track.
				__________________ Bailey '86 Porsche 930 GT1 track car '02 Porsche GT2 '08 Audi RS4 '90 Saab SPG | ||
|  06-07-2004, 08:36 AM |
