WEVO Shift Coupler
I am amazed the difference installing the WEVO shift coupler has made. There is almost no slop in the shifter, I can up/down shift with ease (no more forcing the shift lever into 2nd gear). Gear placement feels much more precise. In general I'm glad I spent the money for this upgrade. (I replaced the bushings in the shifter and "blueprinted" the shift adjustment prior to installing the new coupler.).
Alan
1988 924 S
500 in US
Black (the only color)
82 SC Guards Red/Black . (Sold)
SSI's, No Cat, Bursch, H4's plus relays/wiring upgrade
Old 06-14-2004, 01:54 PM
Binge User
Schrup's Avatar
Sweet Alan, I'm glad you like the results. It didn't take much to break my OEM bushing & I wasn't about to spend $80 on another. Glad I installed one myself. It doesn't make my shifting "CRUNCH" proof if I try to rush too much, but it does make things alot smoother. Are you gonna pony up the 6 large for the shifter?
Paul
Old 06-14-2004, 02:04 PM
v9ff's Avatar
Correct me if I'm wrong, but isn't "large" equal to a thousand dollars?
Old 06-14-2004, 03:12 PM
moazam's Avatar
Send a message via AIM to moazam
Re: WEVO Shift Coupler
Alan
How difficult was the install? Any pics? How long did it take for just the coupler install?
2014 Porsche Cayman S
2001 BMW 525i Touring
1996 Porsche 911 (Gone to Germany)
'86 911 Carrera (Gone to Aruba)
Old 06-14-2004, 03:38 PM
Binge User
Schrup's Avatar
Not on my budget!
Paul
Old 06-14-2004, 03:47 PM
DonMo's Avatar
Send a message via AIM to DonMo Send a message via Yahoo to DonMo
Wevo Coupler $200
Wevo Shifter $600
DonMo
1984 911 Carrera Targa
3.2 liter, SSI's, Dansk 2 to 1, Steve Wong Chip
Columbia, SC
"Go Hokies"
Old 06-14-2004, 04:15 PM
Moazam--
Coupler install was easy(even for me!). Followed directions in 101 projects and the tech article on this board. First time (i tried to replace the bushings in the original coupler) it took 1 hr. Installing the wevo was a snap--30 minutes to remove carpet, access coupler, replace and adjust. (used a 13mm box wrench and socket--I rate the job as a 2 for a first timer, 1-putting air in tires, 10 rebuilding a 915.
Sorry,I didn't take pix.
Alan
1988 924 S
500 in US
Old 06-14-2004, 06:25 PM
