-   -   Windows slow and front vibration (http://forums.pelicanparts.com/porsche-911-technical-forum/166695-windows-slow-front-vibration.html)
ed bates 06-07-2004 04:02 PM
When I recently test drove the car I am purchasing, the windows went down and up rather slow. I don't think this is normal speed. Does this indicate the motors are going or what? I find it odd both are failing at the same time.
As when I got to 40 mph there was a small vibration on the drive. The seller said the front tires need to be balanced, which sounds true...and the front tires are running a little low on tread. Any opinions on this?
Thanks,
Ed
david914 06-07-2004 04:22 PM
Window motors might be OK. Most likely you'll need to remove the window assemblies, then clean and lube everything back up. It makes a world of difference.
As far as the vibrations goes, the tires could definitely cause that. The only way to be sure is to have it checked out. Again, probably a non-issue.
