Hi, anyone know were I can buy this a/c vent or how I can repair it? They are from a 1972 911T and it fix under dash or bulkhead. Help with that guys. The summer is hot!!![img]
http://forums.pelicanparts.com/uploads3/Jun070861086665393.jpg[/img]
1972 911T 1991 Mazda RX-7 Turbo II Are you car loosing power? When was last time you service your fuel injectors? Dirty fuel injectors? Why no try a complete fuel injector cleaning service and return the dignity to you car. Visit www.rennsportfuel.com and we will return your injectors back to life! Last edited by Nitrometano; 06-07-2004 at 08:32 PM.. |
The a/c system is a dealer one. The Porsche dealer sales paper in 14 february of 1972 says that the a/c was installed at the dealer. And was one of the options that the original owner brought.
Thanks Jim for the link!! Any other options guys????
1972 911T 1991 Mazda RX-7 Turbo II Are you car loosing power? When was last time you service your fuel injectors? Dirty fuel injectors? Why no try a complete fuel injector cleaning service and return the dignity to you car. Visit www.rennsportfuel.com and we will return your injectors back to life! |
Dealers installed these "aftermarket" units with the wide (vertical dimension as installed) vent louvers; the "factory" vent louvers are narrower in the vertical direction. Performance Aire is the only source I know for these wider vents. Cheers, Jim
Jim, do you have the Performance Aire web site address or phone number?
1984 Targa |
This is a cheap replacement for a/c vents Cheap replacement for a/c vents
