Are B&B and GHL the only choices for 930 performance exhaust ?
Are B&B and GHL the only choices for 930 performance exhaust ? I've been looking around and I can't seem to find any other choices.
thanks,
Dave
Old 06-08-2004, 08:45 PM
Blaine Sellie's Avatar
Fabspeed is another very good choice.
Blaine
http://www.fabspeed.com/
1988 Porsche 930 Factory Slantnose
2011 Porsche Panamera Twin Turbo
1974 Porsche 914 2.0 Phoenix Red
1965 Shelby Cobra Replica- 428FE
2007 Mercedes SL55 P30 Package
Old 06-08-2004, 09:46 PM
Blaine,
I looked at FabSpeed but all I saw was a muffler. I am going to need the whole system. Did I miss something ? I (will soon) have a 78 930,
Thanks,
Dave
Old 06-08-2004, 09:54 PM
No, you are correct. They offer a dual out combo that has the exhaust exit on the passenger side and the left side is a seperate wastegate exhaust outlet replacing the factory pipe.
Could you use the GHL headers and the fabspeed muffler given it bolts up to the turbo? Probably a stupid question.
Blaine
Old 06-08-2004, 10:26 PM
arrivederci's Avatar
My problem with the Fabspeed dual exhaust is the dummied up wastegate pipe. Also, I haven't heard of any dyno results on the Fabspeed. John Hunt did some dynos with a GHL dual outlet and seemed to have some power gain.
I have the GHL setup on my car...err...had. I sent it back last week to have the right tip properly aligned. When I was taking it off the car, I noticed that one of the welds on the muffler was cracked. So that'll get fixed at the same time.
The GHL headers are great. Their muffler is much better than stock. I put my stock muffler on for emissions about a year ago and the car was a dog even when boost finally hit. The sound of the GHL system is definitely loud (but good, IMO). I think there's some drone under 3000 rpm. It makes talking on the cell phone difficult. Otherwise, I've been very happy. I've had a few comments about how loud it is when on boost. Enthusiasts all think it sounds awesome.
- '72 911T
- '81 911SC Euro
Old 06-09-2004, 04:28 AM
Cymru am Byth
carmad's Avatar
Borla is an alternative, I have seen single and dual outlets on several 930's and they sound pretty good.
I have a GHL dual outlet, sounds great.
1986 930 (Gone but not forgotten)
1995 993 (Should Never Have Sold it)
2007 BMW 328Xi Sport Wagon
2005 Lexus GX470 Offroader
Julian Williams
Old 06-09-2004, 04:36 AM
Don Cothard's Avatar
I had the GHL headers with the Fabspeed muffler worked fine now have the GHL muffler setup and like the sound much better I went with the duel out which is a true duel out not like the fabspeed which is only a single
Don
Imagine Auto Stage 3
87 930
Big Reds
Coil over supension
HP alot (475+)
Torque even more (500 ft lb+)
Old 06-09-2004, 04:39 AM
fireant911's Avatar
Dave,
Although the B&B system may be a possible choice, I would not recommend this system as a true contender for gaining your business. My experience is that the quality and workmanship are not impressive or up to par which is why I removed the B&B system from my car. Resonance from the system was terrible and I found it incredibly too loud for my taste - there was however, a slight improvement in performance but just not worth the 'obnoxiousness' from the system. Since my personal experience is based solely on a 911SC sysyem I cannot say that you would encounter the same problems with your soon-to-be-aquired 930. I believe that there are several highly recommended systems that would prove to be a wise long term investment but I cannot say the same about the B&B.
Daryl G.
1981 911 SC - sold 06/29/12
Old 06-09-2004, 04:47 AM
Thanks for the replys guys. It looks like I'll be going with the GHL. Daryl, I have a '79 that I bought a B&B for and I had the same quality experience. It terms of performance, the US turbo exhaust was so restrictive that you really can pick up 30 or 35 HP by putting a performance exhaust on.
Dave
Old 06-09-2004, 06:23 AM
Jerry S's Avatar
Anybody try Powerhaus.....
I have just the muffler on my 930 and it sounds meaty
Jerry S
Old 06-09-2004, 11:04 AM
Originally posted by fireant911
Dave,
My experience is very different... I run the B&B exhaust and love it. I have no issues with the quality, the sound is perfect (for a weekend car), and the dual exhaust looks bad ass on the 930. Just my $0.02 so you get a both sides.
1986 930 ~ 355 rwhp and 391 rwtq
Old 06-09-2004, 11:12 AM
Don
Just a quick clarification. The GHL does have two muffler outlets, but IMO they're not TRULY dual in the sense of a dual exhaust from a V8. The headers still join each bank of cylinders into 1 pipe right before the turbo, then the muffler splits it back to 2 outlets.
The Fabspeed uses the left outlet for the wastegate only.
Another option for mufflers that nobody mentions is from RUF. While it is expensive, it maintains the stock look much better than anything else. It also comes with the body panels to make the right side cutout look completely stock. You'll have to get those painted, of course...but its the ultimate stocker look IMO. And you usually can't go wrong with RUF parts.
- '72 911T
- '81 911SC Euro
Old 06-09-2004, 11:22 AM
BlkBird's Avatar
GHL header & dual muffler.
Just watch out for the installation. The right outlet has been known to hang lower because way back upstream the turbo didn't mount at the exact right angle to the new header.
Real pain to fix but worth it in the end. And if your shop knows what they are doing, they can even get the car to pass emissions without changing you back to the old stock set up.
C.H.
Boost Addiction - honestly, I have it under control
1989 911 Turbo Cabriolet
Mods include: Kokeln IC, GHL Headers, Hooligan muffler, Modified K27 7200, BL WUR, LC-1 & XD-16, Bilstein Sports (4), TRG sway bars, Oversize torsion bars, Strut brace
Old 06-09-2004, 02:00 PM
Mine has that problem and is currently at GHL to address it. I'm hoping that I can help them fix their jig at the same time that they fix my muffler.
- '72 911T
- '81 911SC Euro
Old 06-09-2004, 03:20 PM
they claim their jig is fine. they said my customer's engine must be twisted in the chassis. ya sure, the old dual outlet RUF unit fit fine. after all the complaints i've heard of the right tailpipe hanging 2" lower than the left, i kinda think it's a jig thing. the muffler would probably be fine on a stock exhaust system, but with their turbo header system, the turbo mounting flange is definitely on the wrong angle, which causes the right side to sit lower. my complaints fell on deaf ears.
206 637 4071
Old 06-09-2004, 03:58 PM
Well, for those who complain, they'll probably continue to handle it on a case by case basis. The result is that some will use other mufflers because they don't want the hassle. Is the RUF muffler aligned properly when used with the GHL headers?
My guess is the GHL got too big -- selling more exhausts for other cars (vettes, audis, subarus, etc). The Porsche community is probably now a small percentage of their sales.
- '72 911T
- '81 911SC Euro
Old 06-09-2004, 05:14 PM
the RUF muffler fit the body properly when it was attached to the stock 930 exchangers, so that would rule out the engine being cockeyed in the body. after the GHL 930 exchangers were installed, the RUF muffler sat at an angle. so it was the exchanger system, not the muffler in this case. i had to drill the turbo and mount plate bolt holes oversize so the turbo could be twisted a bit to help raise the right side of the muffler, and pie-cut the RUF muffler close to the inlet flange, bend upward and reweld to complete the alignment. but "our jig is fine".
206 637 4071
Old 06-10-2004, 09:06 AM
I have a quad outlet Borla that I wouldn't trade for anything. Sound is awesome. I only have euro stock exhausts, and looking forward to either Andial or Powerhaus headers which will both out perform any of the others listed. Brian
Old 06-11-2004, 06:56 AM
