Author of "101 Projects"
Need Help - Photo of Cracked Solder Joint?
Can't say I've ever taken a picture of a cracked solder joint when I went to repair it, but now I wish I had. Anyone have one, or have a cracked joint they could photograph in hires (3 Megapixels min?).
Something like this would be great: ![]() Thanks - this is for a tech article I'm working on right now, on DME repair. Thanks, Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
never ending projects
Not to derail your thread.....but are you planning on doing a 915 tranny rebuild book. Thanks
If you could get some failed DME relays, you can get lots of samples of cracked solder joints like the pic you posted. Wish I took pics of mine before I reflowed it. There were about 6 cracked joints in that one.
You do not have permissi
What causes the cracking? Cheap solder or heat? If it's the latter, wouldn't aftermarket heatsinks/fans solve that problem?
Meanwhile other things are still happening. |
bump - still need pic...
On a great circle route
Russ |
Guest
Posts: n/a
cracked joint
Hmm, this may sound stupid but, perhaps you have an old DME lying around of which you could cause your own solder crack and thus take a picture?
Russ |
