-   -   Cruise Control Problem (http://forums.pelicanparts.com/porsche-911-technical-forum/167050-cruise-control-problem.html)
traveler 06-09-2004 07:37 PM
I do a fair amount of driving on the Interstate in my 87 targa and use the CC most of the time. I find that if I don't use the CC then my radar detector gets more activity than I want it to (if you know what I mean.) Last week I was toolin' down the road staying just under the local radar trigger point when the cruise control just shut off. No matter what I tried, it didn't respond. About 10 minutes later it just started working again.
Any ideas what could be causing this?
:confused:
toolman 06-10-2004 05:26 PM
Try cleaning the conections on the control box under the dash. I determined that my control box was kaput when I could get it to work by tapping on it while trying to engage the control lever. I got a used one and cleaned all the contacts in the stalk and have not had a problem since.
RickM 06-11-2004 02:38 PM
In the Mercedes world a common problem is cracked/poor solder joints in the CC amplifier. Resoldering them usually solves the problem.
Thomas Owen 06-11-2004 03:03 PM
The clutch switch and brake switches are a good place to look as well.
Good luck,
