Oil LIght problem
Can anyone help me solve my problem? I have an 84 Targa, and it has a strange problem as of late. After it is warmed up, whenever the tach drops below 2800-3000 RPM, the parking brake/oil/seat belt light all come on, and stay on until the tach breaks that threshold. Is this a major problem? How can I solve it? Thanks
Air Medal or two
elec problems can be wird.....this one must have a common fault. Do the silly things 1, st- loosen and re tighten all grd conn. is my 1 st guess. The brwn wire is the grd most every where in the car
D troop 3/5 Air Cav,( Bastard CAV) and 162 Assult Helicopter Co- (Vultures) South of Saigon, U Minh Forest, Delta, and all parts in between |
Hi there,
The last time that happened to me, my alternator went soon after. regards,
Jon '85 Targa (recently acquired by Coollx) '02 Carrera 4S (holy moly...I'm in heaven....in the snow too) '06 BMW 325i (gone and forgotten) '03 Honda Odyssey (more dings every day....thanks wifey) |
Did you check your belts?
The Fox Carrera |
What color is the oil light you're seeing; green or red?
red/orange
1984 Porsche 944 (Black) 1984 Porsche 911 Targa (British Racing Green) 1984 Porsche 911 Coupe 1987 Porsche 924S (Guard's Red) |
I do believe red is the alternator light (oil light is green?) - check your owner's manual; you may have an alternator problem.
Driving member
This is exactly the problem I had a couple months ago.
The oil light switch sender is the culprit. It is a 10 to 12 dollar part. The part is almost dead center of the engine top behind the fuel injection/airbox. You need to remove the airbox to get access. The part has a spade connector with a wire connected that sends the signal to the idiot light. I had to use a mirror to see it even after removing the air box. It wasn't bad. About 45 minutes to hour work.
Jerry '86 coupe gone but not forgotten Unlike women, a race car is an inanimate object. Therefore it must, eventually, respond to reason. |
