Running Light
Help!!!
My running lights - Just the Tail are not working! Where do I check? 1982 930 Turbo jasoncfb@yahoo.com http://forums.pelicanparts.com/uploa...1086896615.jpg |
What a cool color!
Sorry, I cant help technically, but that color is hot. Viper green? |
Thank You for the compliment!
Any techs out there? Rear Tail Running Lights do not work - Have checked the bulb, fuse and wires - Any other recommendations? |
check under your dash at the flasher socket, it's to the left of the steering column (the relay is under the hood) sometimes these can work loose and cause similar problems.
p.s......that green is hot.....any more pics? |
Pelican's!
I want to thank this site for the technical support I received. Trouble shooting advise was given - It worked - Thank You!!!! I saved big $$$$$ from taking it to the shop - Also had fun with all the chat. All the running lights work perfectly. I was just a loose relay. Again - Thank You!!!!! ps. Bell is the Man!!!!!! |
the board as a whole is the man :) this is a machine which works very well for us diy'ers :D |
| All times are GMT -8. The time now is 07:00 PM. |
