wheel balance question
I put new front wheels (7X16) on the car -- good tires, swapped from the old wheels (6X16). The new wheels were balanced in the shop, but there's a strong steering wheel vibration above 60 mph. Below that, it's fine, leading me to believe the wheels just weren't balanced correctly the first time. I'm going in tomorrow to have them rebalanced by a better shop, but is there anything else I should look for? I assume if the wheels weren't true, it would be clear at lower speeds.
Any thoughts are appreciated.
89 Carrera 3.4 "There is a right way to go around a corner - it's called the line." -- PCA DE speaker bryteside.com - good things happen. |
One wheel could have a slight bend in it. I had this problem and it was only noticeable above about 60mph.
Jeff
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
Ususally when it appears over 55 MPH it is a balance problem. Try to find a tire store that has the Hunter road force machine that will check for tire runout and broken belts.
87 Carerra Coupe 04 GMC Yukon 07 Mazda 3 00 GMC Sierra |
Designer King
Does this machine balance the wheels while on the car?
Paul Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9 Never leave well enough alone |
