Rust repair question
I have a rust spot under the driver's side rocker. I was wondering if instead of welding in a patch, can I just cut to good metal. Por 15 everything, and then use the 3M panel adheisive instead of welding.http://forums.pelicanparts.com/uploa...1087170280.jpg
Fix it right, Don't half a$$ it. You can weld that in less time than it would take the glue to dry.And it will be done correctly
| All times are GMT -8. The time now is 08:08 AM. |
