I have been driving my car for the last couple weeks and it has this smell. Not oil burning, not greese, not brake fluid, just a strange odor very strong. Well every thing looks and runs OK but the H-4 lights seem to be working very well. On the way home last night I just cound not stand it anymore.....My eyes were starting to hurt. It smelled so strong that I had to stop. Well I opened the engine cover and the motor was not on fire. So I popped the front and Wow did it smell bad....I reached for the battery and felt alot of heat comming off of it. It was over 150f. I turned on all the lights,a/c and audio system to drive the last 2 miles home. Get home pop the hood get meter and 19V. Well anyone need some power for a welder or ? Bummer time for a new voltage regulator. 1972 914 now daily driver again. Race gas is not as expensive as it used to be compared to Super unleaded now. Thanks for listening, Mark
1985 Targa Carrera 1972 914 2.5L four, side shift 1987 944 2005 Husqvarna CR125 1980 YZ125G Last edited by MXMARK; 06-12-2004 at 01:11 PM.. |
I had the same thing once when driving a 911 on around a 1,000 mile trip. God aweful smell. It actually got worse with stuff on or so it seemed. I turned everything off, drove the last 300 miles without it exploding and replaced the voltage regulator. Pretty easy DIY job.
90 C2 Cab Ruf Red/Blk 03 Caynne S L.Blue/Grey 03 996 TT Blk/Blk 04 996 Atlas Grey/Blk |
not for nothing but I use a voltmeter and a marine battery clamp that has a wing nut on the ground. Battery disconnects should be a priority during fire.
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
Ronin Thanks Good Advice. Mark
1985 Targa Carrera 1972 914 2.5L four, side shift 1987 944 2005 Husqvarna CR125 1980 YZ125G |
battery sw is ok but could be more bs.. the wingnut allows a hard direct connect of your new marine ground cable..
My 914 Battery mounted. Hope the picture works.
Sorry did not work Mark
1985 Targa Carrera 1972 914 2.5L four, side shift 1987 944 2005 Husqvarna CR125 1980 YZ125G Last edited by MXMARK; 06-12-2004 at 03:22 PM.. |
You do not have permissi
The engine compartment just got steam cleaned with sulfuric acid. Washy time.
At a high school party a bunch of kids sitting on a dented hood once arced the battery which resulted in a 3-foot fountain and a pizza driver once pulled in with the battery venting steam like a kettle. Saftey first with that stuff.
Meanwhile other things are still happening. |
I might need new carpet in the trunk of my 911 now and all the electric connectors need to be cleaned. No acid or fluid but I still need to clean the damage from the fumes. Thank you Mark
Mark,
I had a similar experience just after I purchased my 88. Prepare yourself for a new battery also as they can be wrecked by the high voltage.
Regards Bruce Past 89 3.2 Carrera (Sold), 94 3.6 Turbo (Sold) Present 94 C36 AMG M-Benz, 93 SL500 M-Benz, 08 C63 AMG M-Benz |
Just a thought, wouldn't it be better to leave lights and other electrical items on in a case like this to reduce the charge available to the battery?
David Cayenne Turbo - Cargraphic Stage 2 Power kit, lowering module 997 C4 Cabriolet - Basalt Black 86 Turbo Body 911 Cab - Many Mods Gone and Missed: 97 993TT: PSS9, CarGraphic Exhaust |
You need a new regulator... get it quick before stuff starts getting toasted. I was running 25 volts and didn't know it.
'74 with webers... Ferdinand Porsche's concerto in flat-six major... |
25 VOLTS STAND BACK!!!!!!!!!!!!! I am not driving it now, the 914 is back in action. Battery is new so hopefully I wont need a new one. If so I will put an Odyssey PC680 battery in the 911. The 914 already has the odyssey PC680. Thanks Mark
