-   -   Spark Plug Differences and Recommnedations (http://forums.pelicanparts.com/porsche-911-technical-forum/167623-spark-plug-differences-recommnedations.html)
Andras 06-14-2004 10:03 AM
I note that Wayne says in his book that Bosch WR5DP are what the 1974-83 stock engines takes.
What is the difference between the WR5DP and the WR6DP plugs, and when would one use the 5 and when use the 6?
Any recommendations?
rlane 06-14-2004 10:36 AM
For Bosch plugs the higher the number the "hotter" the plug (For NGK it is opposite the lower the number the hotter the plug). That said, in general use a hotter plug if you are getting some plug fouling, especially important on a carb'ed car but I see you have a CIS 83 SC. My geuss is that you would not be able to tell much difference between a 5 and a 6...but heck just try both and see how they work. Run them for a half hour or so, cool down , pull a plug and check the color.
