Eric Mckenna's Avatar
Exclamation White SMOKE!!!! even when turned OFF!!
Hey Guys,
I have a question.,. I think I know what it may be but I would like some second opinions.
I have had my car up for about 3 weeks and I have had the rear end jacked up on jack stands..
so it has been sitting at a nose down attitude. ( for 3 weeks now ) I finally put my new 9" fuchs on the rear and i was HAPPY as a HOG in *****!. I tok her out for a 35 minute or so hard run after she warmed up and all from sitting..
I do not have any heat so the pipe from the SSI's are open for now.. and I noticed a small hint of smoke from the right side SSI heater pipe opening.. i figured it was no biggie as the car has been sitting.. so I took off on my drive...
I pulled back in ( about 30-40 minutes later ).. and I turn her off.
now the rear end has white smoke coming out heavy.. I can see it from inside the car so i freak and think she is on FIRE!.. so I pop the rear and get ready to unload the HALON on her.. but it isn't on fire as far as I can see.. it's just smoking big time from the open heater pipe from the SSI's... so I think to myself there must be a fire *inside* the heat exchanger.. so I keep a VERY close eye on this looking for a flame to show at anytime..
but nothing.. and finallly the smoke slows and stops ... but it was still coming out 7 mintes after i had turned the car off..
Do you guys think I have a problem hgere a fire hazard!!.. do you thinki have oil INSIDE the SSI's on the right side?
and if so, how would I get it out.. or should i simply let it bake itself off and keep a very close watch on it..
Please lemme know guys.. sorry if that was hard to follow.. but i am worried to drive the car now as it may burn down to the ground on me and I do NOT want that..
Thanks !
Eric Mckenna
Famous last words..
"Hold my beer and watch this...'
" The reason the Irish are always fightin one another is that there are no other worthy opponents ".
Old 06-10-2004, 05:32 PM
What's wrong with a little fire?
Seriously, burning oil would not produce white smoke. And you would smell oil. Did you hear a hissing sound? Was it wet outside. I think water collect somewhere and it started to evaporate once the engine was hot and standing still.
Beethoven
'88 911 Coupe
Old 06-10-2004, 05:39 PM
No it's wasn't steam like water.. it had a whitish color.. and smelled like a bit of burning oil...
Do you think oil collected up in the HE on the right side and simply started to burn ?
I am worried as my Buddy and i are taking my car this weekend to a car show and I don't want her to burn up.
Is there some way to check the HE for Oil inside of it?
Famous last words..
Old 06-10-2004, 05:45 PM
any ideas?
Famous last words..
Old 06-10-2004, 06:26 PM
Friend of Warren
Eric all that has happened, as you suspect, is that oil has leaked, probably from a return tube, and the oil had made its way into the heat exchanger. Just need to go out and run it longer. Not a big deal, al
Kurt V
Old 06-10-2004, 06:28 PM
Thanks Kurt..
I will take the Halon .. JUST IN CASE! huh...
Thanks.. I guess I should learn from this and not allow it to sit anymore.. MY BAD! porsche are meant to be driven!!!!
Thanks!!
Eric
Famous last words..
Old 06-10-2004, 06:52 PM
Par911's Avatar
Eric, the same white smoke appears under my 911 the sometimes. I have a couple of oil leaks near my return tubes that drip on to my HE's, a little white smoke is no big deal.
Old 06-10-2004, 08:37 PM
Randy Webb's Avatar
Prob. no biggie - take it for a run and see what happens. Keep an eye on the rear view mirror or take a passenger. Or wire up a video cam to a laptop on the pass. seat...
Old 06-10-2004, 09:24 PM
Thanks guys.. I have had the smoke off the outside of the he'S BEFORE .. BUT THIS SMOKE WAS EMITTING FROM THE inside OF THE RIGHTSIDE he HEATER TUBE.. THATS WHAT HAS ME WORRIED LIKE THERE MAY BE A FIRE OR BURNING OIL INSIDE THE he..
DO YOU STILL SAY JUST GO OUT AND RUN IT HARD AND LET IT BAKE OFF?
sorry the caps kicking on by accident. hahah!
Eric
Famous last words..
Old 06-11-2004, 04:31 AM
Noel's Avatar
Eric,
I had a similar situation once, when I disconnected the fan hose to the heat exchanger. My conclusion was that the without the air running through the heat exchanger, they tend to get much much hotter. Thus, the burning of the oil that was inside of the there. Hook the hoses back up and I bet this will stop.
Gone but not forgotten -
1980 Porsche 911SC w/ -22mm/28mm Torsion Bars | Custom Valved Bilsteins | 22mm/21mm Carrera Sway Bars | Elephant Poly/Bronze Bushings | Carrera Brakes | AJ-USA Brake Cooling | Carrera Oil Cooler w/ Fan | Elephant Strut Brace | Oh, and no ABS or PSM or A/C
Old 06-11-2004, 05:20 AM
Where should i hook them up though.. I have removed ALL the heater stuff.
So I simply have pipes off the HE's.. any ideas?
Famous last words..
Old 06-11-2004, 05:47 AM
D@vid's Avatar
Re: White SMOKE!!!! even when turned OFF!!
Maybe a new pope has been elected
1973 2.4 MFI
bone-stock 911T
Old 06-11-2004, 07:00 AM
Eric,
Put a flapper valve on the heater box opening and connect it to your heater cable. This way you can modulate it and you can trail morse code.
Seriously though, don't worry. I'm running mine with heaters disconnected and I see that every time I take the valve covers off because a little oil then runs into the heater boxes. It will burn off soon enough. It's just oxidized and vaporized oil. It does not burn.
Regards
Old 06-11-2004, 07:45 AM
Double Trouble
targa911S's Avatar
yeah those exchangers would have to be a lot hotter than that to catch oil on fire. I like the new pope theory.
I used to be addicted to the hokey pokey..........but I turned myself around..
75 914 1.8
2010 Cayenne base
Old 06-11-2004, 08:38 AM
Noel's Avatar
W/O heat, you will have to live with it and be careful not to get oil on the exchangers when you do valve adjustments and fix any valve cover leaks. If you are planning to take that thing to Mid-Ohio in October, you should get the heat hooked back up. It will help with defrosting and defogging the windows.
Old 06-11-2004, 10:12 AM
Thanks guys for all the helpful stuff.
I feel much better about it all.
Noel..
Nah......i have already pulled it all out. ( it's all dead weight.
I will find a way to work with the fogging issue if it becomes one another way.
i'll simply save my spit for a month and whip it all in the inside of the window. hahahaha
Thanks guys
Famous last words..
Old 06-11-2004, 11:07 AM
Old Member
Eric:
Sent you a PM.
Clifton Brown
https://www.mancalamarketing.com
Old 06-11-2004, 03:00 PM
Old Member
Eric
Were you able to determine anything over the weekend? Curious about my theory.
Clifton Brown
Old 06-14-2004, 10:35 PM
Montana 911
k9handler's Avatar
Send a message via Yahoo to k9handler
so what was it Eric?
H.D. Smith
2009 997.2 S 3.8 PDK
2019 Ford Ranger Lariat FX4 Baby Raptor
2019 Can Am Renegade 1000R XC
2020 Yamaha YFZ450R
Old 06-14-2004, 11:32 PM
Mikkel
Guest
Posts: n/a
Never mind smoke. You got 9 inch Fuchs!!
That calls for pictures you know
Old 06-14-2004, 11:51 PM
