-   -   Name that part game (http://forums.pelicanparts.com/porsche-911-technical-forum/167685-name-part-game.html)
smestas 06-14-2004 02:44 PM
Name that part game
Can anyone here tell me what the name or part# is for the boot next to the throttle and shift linkage boots coming out of the center tunnel to the rear of the car?
Thanks in advance.
smestas 06-14-2004 03:09 PM
Well its the boot for the Speedometer sending unit. It goes where the center tunnel opens to the rear of the car.
Can anyone with PET find tis part number for me (just the boot)?
http://forums.pelicanparts.com/uploa...1087252026.gif
vash 06-14-2004 03:09 PM
i can help you, once i get home.
italcarguy 06-14-2004 03:37 PM
Wish I could help...Is in the Porsche parts books?
SpeedracerIndy 06-14-2004 03:41 PM
Sorry, don't know the part number as I don't have PET, but where does one get the PET? Seems like there are several around here that have it. Or is this one of those things that I'll get thrown in jail for asking?
Martin3.2 06-14-2004 04:09 PM
It seems to be part of the impulse sender (911 606 209 00). The boot is not listed separately.
Martin
klatinn 06-14-2004 04:13 PM
PET-store obviously :D
Sorry, it was too tempting.
smestas 06-14-2004 04:29 PM
Yah Im not to sure why its not listed seperatly since all the other boots near it are (shift linkage boot, accelerator linkage boot). So I really need someone with the PET program to see if it has a unique part#. Once I have that I can add it to my current Pelican order.
I dont think it would hurt too much to run without it but since I have my motor out I better do it while I have the access.
Eric Coffey 06-14-2004 05:37 PM
As Martin mentioned, PET does not list it Specifically. There are two part numbers without corresponding pictures, one of which may be what you are after. I'd double-check with someone who can actually get that part in their hands (and describe it to you) before ordering though:
"Cable Holder" - 911.612.406.01
"Cable Binder" - 999.513.002.40
Or, it may only come as part of the impulse sender assembly as mentioned above.
Good luck!
smestas 06-14-2004 11:59 PM
Thanks for the part numbers guys
Part# 999.513.002.40
is the plastic tie wrap that holds the cable to the tranny
and
Part# 911.612.406.01
is the hard wire type piece that holds the sensor in place (see image above)
All these small things and other boots are available so this one piece should be as well.
Im going to stay in the hunt! Any one else?
Jim Sims 06-15-2004 03:59 AM
Boot only comes as part of the entire sensor assembly; been there, done that. I have a perfectly good sensor assembly with a "rotten" boot. Jim
smestas 06-15-2004 11:10 AM
Bummer!
