Cheap wax on rubber. How do you get it off?
I have these awful looking white blemishes on the rubber components of my car from using zymol. How do I get these stains off? Also, I've seen a couple posts regarding rejex being applied onto your wax coat. What is it?
Many thanks. |
Vinylex and a toothbrush should do it. Or you can use peanut butter (seriously).
They make a solvent name "Prep All" available at AutoZone that is a grease and wax remover prior to painting. It will not harm your finish. Use it with a toothbrush to remove the white wax residue and then use a good vinyl dressing.
I second Vinylex. Good stuff.
Current: 07 S4 Avant, 06 Volvo S60R Sold: '74 911, 01 986, 93 Volvo 240 |
Where can you get Vinylex???
Mike 83 SC |
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
Recreational User
Re: Cheap wax on rubber. How do you get it off?
Vinylex will not work as well. I've tried it. Think about it, you're trying to remove wax, not treat vinyl. And wax is like grease. Best results will be had using a citrus degreaser like P21S Total Auto Wash, or the aforementioned soap and water.
19 years and 17k posts...
The local Murray's Auto Parts here sell Vinylex as well as Lexol for leather. They're both excellent products!
Art Zasadny 1974 Porsche 911 Targa "Helga" (Sold, back home in Germany) Learning the bass guitar Driving Ford company cars now... www.ford.com |
I've seen a lot of detailers use lacquer thinner. YMMV.
Do not use lacquer thinner anywhere near your cars paint, plastic, rubber or vinyl. Most lacquer thinners are very hot, will remove paint and melt rubber and plastic. Try the mild stuff first.
Randy '87 911 Targa '17 Macan GTS |
Student of the obvious
Do you use a rubber treatment on the black bits when you detail your car? Next time treat the rubber FIRST... then the wax comes off easily.
BTW, I just used Dupli Color Bumper Coating (spray can) on an old Honda I'm fixing up to sell. WOW! That stuff works great! The bumpers on this car were bleached white on top from the Arizona sun... taped them and sprayed them and now they look like new. I never expected this stuff to work so well.
Lee |
A citrus-based cleaner called "Goof-off" also works...
I've heard this stuff is good: Wax Blaster
1984 Targa |
Rubbing alcohal and water mixed 1:1
and a tooth brush
86 Targa |
Re: Re: Cheap wax on rubber. How do you get it off?
I use Back to Black on all black parts and it works weel on waxing errors.
90 C2 Cab Ruf Red/Blk 03 Caynne S L.Blue/Grey 03 996 TT Blk/Blk 04 996 Atlas Grey/Blk |
Recreational User
Re: Re: Re: Cheap wax on rubber. How do you get it off?
Meguiars Rubber Care is safe and good for the rubber. Best if done before waxing.
Re: Re: Re: Re: Cheap wax on rubber. How do you get it off?
But, yes, I have tried soap and citrus degreaser and it didn't get me anywhere when dealing with stains left on the front smile from color sanding (white car no less). The only thing that removed the residue/paint from the front smile (which is generally more porous than the bellows or rocker strips) was Vinylex, a toothbrush, and some time. Yes, there are probably other products/techniques that would work, but that is what worked for me. I wouldn't really recommend using powerful degreasers on a routine basis either, and certainly not solvents/alcohol. Keep anything containing silicone (as a dressing) away from it too. Otherwise, you will eventually end up with hard, dried out "checked" rubber. YMMV.
I have no idea what kind of rubber is on you car, but all of my cars have never suffered any damage because of lacquer thinner. The only place I can think of to never use it is the upholstrey. I use it to remove grease and oil from some carpets. I couldn't get along w/o lacquer thinner. Would you care to document some damage you have done or witnessed? Edit: BTW, I have used LT on the smile many, many times. You have no idea what the body shop does with this stuff. They practically bathe the car in it. Last edited by Zeke; 06-12-2004 at 06:26 PM.. |
