-   -   trans. problems (http://forums.pelicanparts.com/porsche-911-technical-forum/167777-trans-problems.html)
MARK SHUART 06-15-2004 03:46 AM
trans. problems
have a 1970 911 took out for first time went about a 1/4 of a mile, then came out of gear at stop sign and could not get into 1,2,3 or R, like it jamed or shifter is stuck? I can get into 4 and 5th is the tran. gone? any idea?? thanks mark
Jim Sims 06-15-2004 08:51 PM
Check the shift coupling under the plate on the floor behind and between the seats. It may be loose or the plastic bushings in it are bad. Jim
