Is adhesive even necessary w/Doorskins?
Subject says it all. Factory only spot welded in 4 or 5 places along the bottom and rear edge, and I'd like to use rust bloc between the frame and skin, so can I do without the adhesive?
The adhesive is the strength of the bond between the two panels. You would rather do without the spot welds than the adhesive.
87 Carerra Coupe 04 GMC Yukon 07 Mazda 3 00 GMC Sierra |
