-   -   what adhesive to use to hold power window in the channel? (http://forums.pelicanparts.com/porsche-911-technical-forum/167944-what-adhesive-use-hold-power-window-channel.html)
John Brandt 06-16-2004 08:16 AM
I'm referring to the channell that grips the window and pulls it down with the power window mechanism.
mine came loose again. as it did about 5years ago. Last time I used some kind of clear silicone goop / caulk
it wasn't a pleasant job, and I'd prefer not to need to do this yet again in a few years. Got any thoughts on what would be a more permanent solution?
TerryH 06-16-2004 08:45 AM
Use quick set urethane after a thorough cleaning with degreaser. Make sure things aren't binding. The window should almost drop with gravity. You may want to lube the regulator and the glass run channel.
John Brandt 06-16-2004 11:48 AM
thanks,
so perhaps silicone spray on the runners and lithium grease on the inside equipment?
TerryBPP 06-16-2004 11:51 AM
Wayne told me to use 3M waterproof marine adhesive. It comes in a white/green tube. Worked great.
TerryH 06-16-2004 01:16 PM
Originally posted by John Brandt
thanks,
Those are the same lubricants I use. The quickset or fastset automotive glass urethane is very permanent. I would venture to say it's so permanent that something will break, ie; glass or metal regulator, before the bond lets go. ;)
Like any repair of this sort, prep the area real well to get a good bond. I would use naptha or acetone to get good oil free surfaces.
dotorg 06-16-2004 01:19 PM
I used the 3m marine adhesive, too. It may be worth replacing the channel inserts, too, in case thats causing the window to bind. They're not terribly expensive.
david914 06-17-2004 05:08 AM
I went to a local glass shop. They gave me the remainder of a tube of urethane that is used to glue in windshields. Apparently, they frequently have partially used tubes of adhesive that just get thrown out since once opened, they don't have any shelf life. Worked great.
