ckmaggie's Avatar
Jacking up front (pics)
Preparing to do suspension work and lifted up front. Before I crawl under wanted thoughts on how I supported.
Chris
1985 Carrera
http://www.pelicanparts.com/gallery/ckmaggie
Old 06-16-2004, 06:54 AM
"C-Rations"
JRISER's Avatar
I'd like to know, too!
John
The Stable:
1985 Carrera Cabriolet (RoW) Sold
2002 Chevy Tahoe LT (The Wife's)
1999 Chevy Silverado (Parts Hauler)
1969 Volkswagen Beetle (Purchased From Original Owner)
I'm slower than the guy in front of me, but faster than the guy in back of me.
Old 06-16-2004, 07:02 AM
Friend of Warren
Looks fine to me. That is where I support the front when doing suspension work. I also move the tires up just behind the jack stands and shim the space between the tire and bottom of the car with some wood, just in case the jack stand was to fail. Just some additional insurance.
Kurt V
Old 06-16-2004, 07:05 AM
Odd looking, but it's correct, right?
Old 06-16-2004, 07:14 AM
Zeke's Avatar
I like that kind of stand in the 6 ton model. It's more stable to use than short stands w.o extending too much. The wood block acoss the stand top is better than parallel like in the 1st pic.
Make sure to examine the wood for a decent piece that won't split in two. As a carpenter, I guess that's easier for me. Let me just say the grain should not run up and down. Side to side "flat grain" lumber is best. Longer is good too.
The wood grain in those two pics looks ggod.
Old 06-16-2004, 07:20 AM
Better in Person
juanbenae's Avatar
i actually use a 2x4 that i beveled the same angle as the V postion of my floor jacks. i put the beveled side into the floor jack pads and the flat (wide) portion on the tub area as you have. i also ran the 2x4 one piece the entire width of the car. it really seemed to solidify the entire set up by tying the two stands together with the long 2x.
Old 06-16-2004, 07:23 AM
cantdrv55's Avatar
Hey, Chris where'd you lift it from? The placement of the stands look fine to me.
Old 06-16-2004, 07:24 AM
ckmaggie's Avatar
I jacked up each side via the access hole with jack pad.
Chris
1985 Carrera
Old 06-16-2004, 07:26 AM
What?
trj911's Avatar
Looks good to me too. Nice bike!
Tom J.
911SC Cab
SCWDP
CaymanS
Old 06-16-2004, 08:54 AM
ckmaggie's Avatar
Bike is my daughters, but I have been known to take it for a spin now and again.
I figured I should show the "other" side on the car now that you have all seen the bottom.
Chris
1985 Carrera
Old 06-16-2004, 08:59 AM
What?
trj911's Avatar
It looks much better from that angle. There is something about a red car that I really like!
Tom J.
911SC Cab
SCWDP
CaymanS
Old 06-16-2004, 09:01 AM
Looking at your car, I get the feeling somebody might of lowered the front of my car and not the back. Dang your car is perfectly level. Is that the stock look?
Old 06-16-2004, 10:56 AM
Friend of Warren
Looks like US ride height. I would lower to Euro specs. 25 1/2" in front and 25" in back.
Kurt V
Old 06-16-2004, 11:00 AM
Everything is sloped in these pictures, kind of hard to tell.
Old 06-16-2004, 11:11 AM
ckmaggie's Avatar
It is at US spec. Part of the suspension work I have planned is to lower to Euro specs. Not sure if I will try to do the back w stock spring plates or buy the Sway Away adjustables.
Any input is welcomed.
Chris
Chris
1985 Carrera
Old 06-16-2004, 11:40 AM
Friend of Warren
Chris keep in mind your rear spring plates have 3/4"-1" of up and down adjustment before you have to pull the torsion bars and reindex. Unfortunately I had to reindex mine. Assuming the torsion bars are not stuck, it is about a 2 hour job.
Here is a pic of mine at Euro height:
Kurt V
Old 06-16-2004, 11:54 AM
ckmaggie's Avatar
They do??? Do I just loosen the bolts to lower the inch or so?
Chris
Chris
1985 Carrera
Old 06-16-2004, 12:26 PM
Friend of Warren
Chris
Chris, do you have Wayne's 101 Projects Book? If not get it. It describes (with pictures) how to lower your car along with 100 other projects to suck up your time and money!
Kurt V
Old 06-16-2004, 12:31 PM
Kurt,
Aren't you a little old to be trolling the local high schools in a very nice Porsche?
Neil
'73 911S targa
Old 06-16-2004, 01:02 PM
Senior Member
Jdub's Avatar
Can you slide the tbar out backways with the block of wood where it is?
I would consider cutting slots in a block of wood about half the size of those that fit into the body seams at the very sidemost, outermost, behind the wheel areas. That's what I did and it works great.
You want less wood block I am thinking anyways.
John
'78 Targa in Minerva Blue
Old 06-16-2004, 01:49 PM
