-   -   Intermediate stud pulled (http://forums.pelicanparts.com/porsche-911-technical-forum/168052-intermediate-stud-pulled.html)
Bigtoe 06-16-2004 08:10 PM
I'm past the denial phase... My engine leaks oil.:rolleyes:
While investigating the source I noticed a rather large leak at the
intermediate shaft bearing journal case stud nut. (Whew!) Just as discussed in older threads via the search function my fastener was only finger tight and would not torque down.
I guess that the only true repair would be to split the case :(
and install a helicoil.
But, golly-gee fellas she's a runnin' so good!
I saw posts from Superman and Vash. Any info on the long term results of the interim fix?
Anyone else have this problem? Fixes?
john walker's workshop 06-17-2004 07:54 AM
remove the stud and tap the hole 10x1.25 about 1" deep. install a short bolt with an aluminum sealing ring and don't worry about it until you eventually rebuild it. the hole takes the tap without further drilling, and there's really no damage done where you can't go back to a 8mm stud/washer/nut.
Bigtoe 06-17-2004 11:35 AM
Thanks JW!
I'll plug it and let it ride.
scottb 06-17-2004 02:27 PM
Everytime I see one of JW's simple, practical yet effective solutions, I shake my head and smile.
JW, YOU ARE DA MAN!!! http://www.pelicanparts.com/support/...s/beerchug.gif
kach22i 06-17-2004 02:37 PM
More notes for my Porsche degree.:)
Alan Cottrill 06-17-2004 04:50 PM
I think you worked on my car back in the day. I found mine had that "mod" when I rebuild the engine. it worked like a charm. when I had it apart I installed a thread insert.
vash 06-17-2004 11:16 PM
how about a really big c-clamp? just kidding, i am still putting off the same repair. but right now, my copper silicone "booger" is doing the job. sorry toe. please, please post pictures. for my future reference.
Ho Hum 74 06-18-2004 06:20 AM
John,
This is what I was thinking for my problem. I have the same, "finger-tight" stud but on the top of the timing chain housing (more difficult to reach). It's one of those 13mm nuts. What size tap should I get?
Tristan
john walker's workshop 06-18-2004 07:55 AM
hard to say on that one. specifically, which stud?
Ho Hum 74 06-18-2004 11:05 AM
John,
It's the one on the top right side (passenger) of the engine. It attaches the timing chain box (not cover) to the case. It has a 13mm nut to fasten it. I guess it's the same as all the other case parting line studs.
Tristan
john walker's workshop 06-18-2004 12:31 PM
that one has a steel alignment sleeve at the parting line, so not much you can do without removing the housing except try to use a longer stud to maybe pick up a few unused threads at the bottom of the hole.
Porsche 2 02-11-2018 05:20 PM
Hi John,
I just completed repairing the intermediate bearing stud oil leak by tapping in with a M10x1.25 tap and inserting a M10x3/4" long fully threaded bolt per your suggestion, see pic. Removing the original M8 approx. 3" long stud proved very difficult as previous owner had used what looks like JB weld (grey material) with a remnant lump that would not let me remove the final approximately 1/2 inch of the stud. So I used my dremel cutter and cut the stud off leaving about 3/4" in the stud hole which I pushed back towards the bottom of the hole.
I assume that piece of stud will stay in the stud hole until one day in the future when this case is split again. Is my assumption correct?
Thanks for your attention and I am looking forward to your answer.
Cheers, Keith.http://forums.pelicanparts.com/uploa...1518398378.jpg
Jack Stands 02-12-2018 01:05 PM
That’s a blind hole, so that won’t go anywhere but will cause head scratching for the next person that splits the case. I had the same stripped out intermediate shaft bolt on my 2.7, and the tapped bolt worked great till the engine was rebuilt several years later.
