Heck, I’m only 5 not 71!
targa80's Avatar
Finally done painting?
Well all of the piece parts have been painted and the paint booth has been taken down. I am in the process of temporarily fitting the larger body parts on the chassis so I can wet sand and compund out the nibs (specks of grit) in the clear coat. When I am done with that I will push it back into the garage and take it off the rotisserie and mount the chassis on jack stands for the start of reassembly of all the guts. First I have to clean and recondition what I can and replace anything that needs replacing. At the rate I work I don't expect to be driving soon. But that is ok I am not in a rush yet. Here are some pics of the work I have done recently.
Pat Henry
Targa80
1980SC Targa (Mocha Brown)
Old 06-12-2004, 09:17 AM
targa80's Avatar
I left this pic out as you can see there is not much room in the garage with all the body parts off the car.
Pat Henry
Targa80
Old 06-12-2004, 09:21 AM
19 years and 17k posts...
azasadny's Avatar
Pat,
Your neighbors must just love you! (just kidding)... Your car is going to be fantastic!
Art Zasadny
Learning the bass guitar
www.ford.com
Old 06-12-2004, 09:36 AM
Mark Wilson
Guest
Posts: n/a
Pat,
You need to write a book after this. Great job on what is most certainly a labor of love!
Old 06-12-2004, 10:16 AM
Excellent!
How far off the rotating axis were the body mounts??
Dennis H. 72 911E 2.7 RS stuff
72 911T with a 2.7(Sold 5-13-2011)
2012 Kona Blue Metallic Mustang GT Convertible 6spd
67 Mustang coupe future SVRA group 6 car
63 Falcon hardtop 302/4spd
Old 06-12-2004, 10:53 AM
targa80's Avatar
Originally posted by 724doorE
Excellent!
I used the front and rear bumper shock mount points to set the car on the rotisserie correctly.
Pat Henry
Targa80
Old 06-12-2004, 02:53 PM
looks like a class act.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 06-12-2004, 03:05 PM
dtw dtw is offline
GAFB
Very nice. This has been a long time coming. Good luck on the reassembly. Should be a bit less tedious than sand then spray, sand then spray, sand then spray.
Several BMWs
Old 06-12-2004, 05:04 PM
Randy Webb's Avatar
I'm amazed -- Camarillo doesn't have any laws against this?
Good luck.
Old 06-12-2004, 06:03 PM
Craig Roche's Avatar
You are most certainly "the man" in my book! Looking good!!!!!!!! Thanks for the photos
Craig
1984 911 Targa
Old 06-12-2004, 07:30 PM
Zeke's Avatar
Good luck.
Old 06-12-2004, 08:35 PM
maxnine11's Avatar
looks great Pat!! I think you are over the hump now.
put a few of those parts back together and it will start to look like a 911
max
max
Old 06-12-2004, 09:39 PM
The Chef
Guest
Posts: n/a
looks great! keep us posted.
Old 06-12-2004, 10:03 PM
Hey, Pat
If you need some extra hands hanging doors or? send me an email, Or call I think you have my number? You can look at my SC to see where all the parts go, Except for the roof of course
I'd like to see this project
Bob
Old 06-13-2004, 09:12 AM
Par911's Avatar
Beatiful work on the paint job! That mocha looks sweet.
Old 06-13-2004, 10:11 PM
What?!?!
DonDavis's Avatar
Seriously impressive!! Can't wait to see more progress. Do you have a target date for completion or are you just playing by ear?
running shoes, couple tools, fishing pole
1996 Subaru Legacy Outback AWD, 5speed
2002 Subaru Impreza WRX, 5speed
2014 Tundra SR5, 4x4
1964 Land Rover SII A 109 - sold this albatross
Old 06-13-2004, 11:49 PM
I wish I was your neighbor, thanks for documenting the project. Paint looks great!
John Adams
1980 ROW 911SC
Old 06-14-2004, 06:13 AM
targa80's Avatar
I'm just playing by ear, I originally though it would take a 1 to 1 1/2 years to do. I am almost at that mark now and a long way from being done. There is so much more to do I don't have the excitement in me to say hurry up and you can drive it. I'll get there in my own time and hopefully it will all work out to my satisfaction.
Pat Henry
Targa80
Old 06-14-2004, 07:09 AM
DG624's Avatar
Looks like the pinting was the easy part. How did you get everything apart? I was told that removing the fenders was difficult because they are glued to the body. Does this sound right?
Old 06-14-2004, 07:26 AM
targa80's Avatar
No, they are not glued to the body. There is a putty like substance that is placed between the fender edge and the chassis edge. This is where the fender bolts to the frame in the luggage compartment. There are bolts holding the fender to the door frame and are located behind/under the fender wheel well. Those bolts are covered with Wurth Body Schultz (undercoating). Once you have removed all of the bolts from the fender and body. Seperating the fender from the chassis can be done. A thin putty knife can be used to help loosen up the putty if needed beteen the fender and the luggage compartment.
Pat Henry
Targa80
Old 06-14-2004, 08:30 AM
