I can't flash my head lights ? PLEASE HELP
I have a 76 911 and the head lights will not flash from low to high? Is there a relay that controlls this function? I can see a relay socket just behind the turn signal relay. Is there a relay missing. Just to make it clear I can go from high to low beams by moving the switch, (forward=high beam) pull back and I have low beam. But if I pull the switch back towards the wheel to flash the high beams nothing happens.
I hope that you guys can understand what I'm talking about Any help would be great:) |
Sounds like the stalk switch has gone kaput. Don't bother trying to fix your old switch...if you're going to the trouble of removing it, replace it with a new one from our host.
I had the same problem and bothered to fix it. There's nothing magical about these switches, so if you have a basic understanding of electricity its actually a pretty easy fix. I posted a thread with pictures here :http://forums.pelicanparts.com/porsche-911-technical-forum/123017-turn-signal-switch-repair.html.
If you're not the electrical repair type, then buying a new one is probably the safest bet. Almost a year later, and my repaired switch is still fine. |
Thanks Guy's I'll look in to this
| All times are GMT -8. The time now is 01:52 PM. |
