-   -   When I hit my brakes the blinker speed slows down.... (http://forums.pelicanparts.com/porsche-911-technical-forum/168073-when-i-hit-my-brakes-blinker-speed-slows-down.html)
svonkampen 06-16-2004 10:49 PM
And if my headlights are also on they really slow down........
Will a new battery fix this?
Anyone else had this problem?
SvK
scottb 06-17-2004 12:01 AM
I haven't had a similar problem, but I'd be willing to bet your alternator and/or regulator are shot. Put a volt meter on the alternator and check your readings when you turn on the lights, hit the brakes, etc.
GeorgeK 06-17-2004 12:51 AM
Bad earth is also a possibility. I saw a car that had no brake lights only when the engine was turning. Cleaning the earths solved the problem.
xlr8 06-17-2004 04:08 AM
How close do you drive to the speed of light? :D
project935 06-17-2004 08:33 AM
You're low on blinker fluid :)
Ray 911s 06-17-2004 09:22 AM
Does the blinker indicator (arrow in the dash gage) also get dimmer when the blink rate slows? Or possibly both indicators glow dimly? You may have one blown brake lamp bulb. Do a walk around and check all the lights and have someone watch your brake lights for you.
Bad ground or blown bulb will both account for this symptom. Other things can also cause this symptom, but might as well start the diagnosis with the cheap items!
cegerer 06-17-2004 09:26 AM
There's a ground wire near the right rear tailight assembly that could cause this. As I recall, you'll need to remove the housing to access it.
MAS 06-17-2004 09:41 AM
Yeah... a bad earth/ground could easily be the problem. Most likely in or around one (or both) of the tail light assemblies. It's fairly easy to pull them apart and clean all of the contacts.
If it is the fan belt slipping, then the same thing would not happen at idle (or at least, I can't think why). Easy experiment, anyway.
PS... I had a similar problem... it was a bad ground in one of the tail light assemblies.
-MAS
KobaltBlau 06-17-2004 11:45 AM
Dang, Russ. LOL. very funny!
