1st start, 2.7, PMO, E, SSI
for friends who have been following my act.
New cams had to be taken serious at 1st start imo.. The e-cams were both timed equal twords max advance. that sounded ok. The carbs are set very basic twords rich so as just to keep this thing from blowing up for the cam break-in.. it's still running. [it's been down since early august]. I used 30w non-detergent cause if it's good enough for the rings it's good enough for me. so wtf.. anyway very nice crude results. I'm hoping to use the CHT/EGT computer to assist in having 6 ir carbs create equal +-50deg EGTs. The display shows a 6 bar graph and dig numbers within +-2%.
cool
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 06-17-2004, 05:13 PM
Bandwidth AbUser
Jim Richards's Avatar
Re: 1st start, 2.7, PMO, E, SSI
cool
Good one, Ron! Should make cruising LI even more fun.
Jim R.
Old 06-17-2004, 05:57 PM
Early_S_Man's Avatar
Porsche Crest
Sounds great, Ron!!!
You can always go to 'S' or GE-60 cams later with those RS pistons riding comfortably in their Nikasils ... after building a Donohue-geared 915 transaxle like the one charted below!
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 06-17-2004, 06:03 PM
thanks for the chart.. not exactly the gearing I that I was thinking about for my rides. I want to feel out what I have now.. then maybe tweak per the torque curve..
Jim.. gearing is life. your RS eng will be alive with selected gearing for what you want to do. If you have a favorate track? that's your envelope imo.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 06-18-2004, 10:41 AM
makaio's Avatar
Right on! Can't wait to see it on your next ride.
Old 06-18-2004, 02:20 PM
Bandwidth AbUser
Originally posted by RoninLB Jim.. gearing is life.
I have to remember that quote, Ron.
Jim R.
Old 06-18-2004, 03:27 PM
