-   -   Another first DE - brake help (http://forums.pelicanparts.com/porsche-911-technical-forum/168304-another-first-de-brake-help.html)
Speed Buggy 06-18-2004 10:23 AM
Aloha - I did my first DE Thursday. What a blast! I have a question about brake feel though. I couldn't get too close to the corners because my brakes didn't feel that strong. I changed out the fluid (Synpower) and bled them last weekend, several times around. I know my instructor wanted me to stay on the power longer but I still would stand on the brakes coming into a corner and they would feel mushy and I didn't feel too confident in their ability. Could this be old brake lines, or did I not do a good job of bleeding. The pads are > 70%. Any help would be greatly appreciated.
P.S. also still grinning. Boy was I exhausted last night.
Jim Richards 06-18-2004 10:26 AM
Did the brakes feel that way all day, Speed Buggy, or did they feel worse as the day went on?
Speed Buggy 06-18-2004 10:31 AM
I don't believe they were real strong to begin with. I don't know if they got worse throughout the day, or if I was pushing it more each session and noticed it more. This was my first session so I was probably paying more attention to the track to begin with and more on the car as the day went on.
Mike
Doug Steinel 06-18-2004 10:32 AM
How old are the rubber lines? If they are old they expand which can give the feeling of a mushy pedal. Also, did you pound the calipers with a rubber mallet vigorously when bleeding? You could have a few small air bubbles in the system.
Doug
Speed Buggy 06-18-2004 10:36 AM
Didn't "excersize" the calipers. I don't know how old the lines are. I will replace them. I can't imagine the PO did much in the way of maintenance now that I have been under the car. I will also bang the calipers while bleeding after the line replacement. Thank you.
Cheers, Mike
Wil Ferch 06-18-2004 10:38 AM
Stock pads at 70% ??
Try a performance pad like Porterfield or Pagid...
How is your braking style....hint..get on them rather hard after they first "bite-in"...then gradually let up until you come to the end of your braking zone before you turn-in. Most newbies "slide into" the brakes and brake harder-and-harder in the braking zone before they let up to turn-in. This style *really* tends to fade the brakes !!
---Wil
Speed Buggy 06-18-2004 10:45 AM
I will try different pads. My instructor took me for a ride in his M3 and showed me the difference between the way I applied the brakes on my first run and the way you describe. My second and subsequent (sp?) runs, I was getting the head nod at each corner when I hit the brakes. Obviously on my first track day I was not great at it, but my instructor said the brake application was correct, (or beginning to be). Thank you
Cheers, Mike
toolman 06-18-2004 04:27 PM
Mike, Let me know if you need help doing those brakes, I did mine last fall and they turned ouut great. Plus it would be a good reason to take the 911 for a ride.
porschenut 06-18-2004 06:49 PM
---Wil
Is this what they mean by "trail braking"?
Wil Ferch 06-19-2004 09:22 AM
No...this is not trail braking.
Trail braking is not completing your (amount) of braking while you're in a straight line, and thereby you're still braking as you enter the turn.
For most 911 drivers...and especially newbies..don't trail brake. Get all your braking done in a straight line before you "turn-in"...
Trail braking induces...as you would imagine...a degree of oversteer that would be very hard to control...especially at the end of a high speed straight.
---Wil
