moosthuizen's Avatar
Valve adj done - thanks
Thanks to all of you for your input and advice.
I did it. After having everything ready I was a bit scared to get started. But it turned out to be a walk in the park. Yes it is almost impossible to get the feeler into the gap, but what I did was to loosen the nut until I could get the feeler in, and then with the feelet still in tightened it again.
After checking the gaps the 4th time, I decided I had the "feel". Then adjusted and checked with "feel" where I could not get the feeler into.
Started her up, what an improvement on sound! I had a lot of tapping noises before, which are now gone. The accelaration is also much smoother now.
I think I was a bit conservative as there seem to be one or two valves still tapping. I blame it on "loos is better than to tight" theory. Sounds like one on the bottom of both sides is still on the loose side.
I might give it another go this weekend, am sure I'll be able to do it in 1 or 2 hours this time round.
Marius
80 911 sc
Old 06-17-2004, 11:55 PM
good going amigo ! l had a similar experience first time around.These engines are pretty simple but mistakes can be very costly as we all know.After my first adjustment l second guessed myself right to another shop that had a well known P-car tech l respected,and had him check my work.He said he didn`t have to change anything,perfect adjustment.Cost me a bit but l had worried myself silly thinking l`d gotten one too tight.Long time ago and pretty funny now but l`m glad l had a second opinion.l love that car,life wouldn`t be the same without it
my life begins at 150MPH
Old 06-18-2004, 12:26 AM
Know the feeling! I admit to being very anxious just before I started her up, after doing the adjustment.
It helps to be on the safe side. Today you can laugh about your own experience. Great feeling to know that you did not screw things up!
Marius
80 911 sc
M Oosthuizen
'87 Carrera
'80 SC Sold
Old 06-18-2004, 01:44 AM
Designer King
Paulporsche's Avatar
Good job! You give the rest of us hope.
Paul
Paul
Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9
Never leave well enough alone
Old 06-18-2004, 02:02 PM
goat's Avatar
Bravo!
I got a valve adjustment in my near future, and I do need to hear about maintance jobs gone right.
Tim.
1988 911 Carrera. Silver.
1973 914 Metalic Blue.
2012 Cayenne S
Old 06-18-2004, 02:07 PM
