Angry Gas Tank pulley broken...out...of...gas!
I have an '85 911 Targa. The pulley on the inside of the car on the dashboard rusted and broke while I was at the gas station. I can no longer open my gas cap. How do I jimmy the lid on the gas cap cover to pop open? I am low on fuel and have to park the vehicle until I come up with a solution. Thanx.
Old 06-18-2004, 01:43 PM
there's plenty of room to slip a bent coathanger or welding rod down past the flap to release the catch. you've seen how it works i'm sure.
206 637 4071
Old 06-18-2004, 01:48 PM
I see there's room, but I do not know how the latch works. It seems as though I'll have to catch another 911 owner and ask him to open his latch. Is there any site on the net with a screenshot of an open latch or at least a figure/diagram of the tank lid?
Old 06-18-2004, 01:55 PM
Eric Coffey's Avatar
If you can't grab any of the remaining cable to release the catch, you can remove the whole flap by unscrewing the 3 (4mm hex) hinge bolts located up under the LF fender. Good luck!
EDIT: Yeah, I'd definitely try JW's method first. Just mind your paint.
Old 06-18-2004, 01:58 PM
KobaltBlau's Avatar
When I saw this title I was thinking .... blinker fluid .... muffler bearings .... gas tank pulley.
Andy
Old 06-18-2004, 02:09 PM
I carry some heavy mono fishing line. slip it under and across while holding from left to right.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 06-18-2004, 02:19 PM
Ronin's string thing works perfectly. I carry a piece of nylon string with finger-loops at each end, in the glovebox. Every once in awhile, the tee handle will come off the end of the cable, unthread itself, and I have to use the string. Works just fine, no need to risk scratching paint.
Stephan
Stephan Wilkinson
'83 911SC Gold-Plated Porsche
'04 replacement Boxster
Old 06-18-2004, 03:02 PM
pwd72s's Avatar
yup! Since I learned this trick (on this board, by the way) I have a wrap of nylon cord securely taped to the handle of my flashlight...it's there "just in case". As Ron said, left to right, then pull boths sides back toward the latch...toward the rear of the car. The cord catches & releases the latch hook...bingo, you're open. Easy, once you learn the trick...And now we've just told thieves how to syphon gas from a P-car!
Old 06-18-2004, 03:17 PM
Thanx guys. I figured it out using a very narrow and thin flat-head screwdriver.
Old 06-20-2004, 05:52 AM
