grahamkissack's Avatar
remove both vac lines to time a 1980?
I'm just fine tuning and will be rechecking my timing. Bentley isn't specific...do I remove both vac lines from the distributor before timing to Z1 at about 950 rpm with the engine warm?
Thanks, Graham
"Penelope" 1980 SC Targa in Grand Prix White
Old 07-27-2004, 10:44 PM
Yes I believe you do remove both lines. But I think you want to set total advance at 4k rpm. Then you check the idle advance.
Dean
Dean
911 SC turbo, 3.0L 930 motor, G50, 930 brakes, DTA EFI, 352 RWHP DynoDynamic dyno,
Old 07-28-2004, 06:54 AM
both hoses off, turn down idle to 950, set timing to spec, reattach hoses and reset idle speed.
206 637 4071
Old 07-28-2004, 08:34 AM
