-   -   Crank Trigger position (http://forums.pelicanparts.com/porsche-911-technical-forum/168442-crank-trigger-position.html)
magic930 06-19-2004 07:43 AM
Anybody out there with a crank trigger wheel on the pulley...
Could you tell me where the missing teeth are in relation to TDC and the sensor?
Matt-Man 06-19-2004 08:21 AM
For standard timing, the sensor is aligned exactly at the trailing edge of the 11th tooth after the two missing teeth. This is done at TDC #1. You can download the complete instruction manual at Electromotive's website.
Matt
