1973911s's Avatar
How do you measure tire height
I bought some AVS-ES100 and they look to tall on my car, they seem to come out from the rim, as if they bulge out. I would like a tire that is even with the rim, and goes straight up. So I am trying to find out if there is a place that post the spec on how tall a tire by a specific manufacture is?
What do you call the measurement of the height of the tire?
Thanks for your help.
Michael
1984 Carrera Targa Sold to fellow Pelican
1973 911S Targa - Sold to fellow Pelican.
Old 06-18-2004, 07:53 PM
stormcrow's Avatar
Go to this web site and this should answer your questions
http://www.miata.net/garage/tirecalc.html
"A Porsche does more then just go fast in a straight line"
SteveKJR
Proud Owner of a 78 911 SC Targa
Old 06-18-2004, 07:56 PM
Early_S_Man's Avatar
Porsche Crest
Tire Rack has a specs page for every line of tires they sell ...
http://www.tirerack.com/tires/Spec.jsp?make=Yokohama&model=AVS+ES100&partnum=445WR6ES100
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 06-19-2004, 08:51 AM
1973911s's Avatar
Early S Man,
Thanks, I have been there, but haven't been able to find a height of the tire dimension they sell.
Michael
Old 06-19-2004, 10:37 AM
Yellowbird RS's Avatar
(225/45R17) 45 indicates the height of the tire wall, and it is 45% of the tire width (rolling ribbon), inflated at the indicated by the manufacturer psi. 225/45R17 = 225mm/101.25mmR17
X/A
Old 06-19-2004, 11:55 AM
Rim Width
The width between the flanges of the wheel (the part the bead of the tire touches).
Section Width
The linear distance between the outside of the sidewalls of an inflated tire without any load on it (this does not include any sidewall decorations).
Section Height
This is also known as the Aspect Ratio. This is figured on a percentage of the section width. A tire size of 205/60R15 would have a section width of 205 millimeters and a section height of 60 percent of 205 millimeters.
X/A
Old 06-19-2004, 12:29 PM
