-   -   Question about lowering front end (http://forums.pelicanparts.com/porsche-911-technical-forum/168529-question-about-lowering-front-end.html)
1973911s 06-19-2004 08:09 PM
I have lowered the front end, I took it to the point that the 11mm nut came really loose, and can't get the car as low as I like.
Is it possiable that I can back the screw out to far?
Any other ideas to lower the front?
Michael
911nut 06-19-2004 08:34 PM
Take the adjusting screw completely out. Pull off the adjusting arm and re-index it with the arm toward the floor. Put the screw back in and set the screw so that 10 threads are showing out the top of the arm. If you have stock torsion bars that should get you close.
