Tom and others have BTDT. It is good advice.
If I wanted a nice engine to replace what I have, starting "new", a stock 3.2 with cat bypass, MAS air flow and a chip would keep me happy. Drop the weight on the car an zoom/zoom ;) 220 at the wheels and 200# or torque with electronic fuel management. Still the best transplant for the money IMO. |
Thanks for all of the advice. Sometimes I'm a slow learner, but once I saw all of the numbers I s l o w l y started to understand. I still plan to build a motor, but I think I'll take it a bit slower and do a bit more planning.
-Jon |
A very nice upgrade for the 3.2 is Euro higher compression pistons and a better cam (964, 20/21). Set it up with a chip for the type of gas you want to run and your good to go. I've driven them and they are fast.
A good 3.0 would push around that '76 quite well. You just wouldn't have the 3.4 bragging rights. You could get one heck of a 3.0 that was professionally built for about 10k or less since you already have the exhaust.
Even a stock Motronic 3.2 isn't in the same ball game as a decent 3.4 CIS if mine is any indication. Not trying to convince anyone that a 3.4 CIS is a good move unless you have specific circumstances like mine. But a 3.2 with a few mods and less than 6 or 7K$ (including the engine) will get you a darn fast motor and modern, programable fuel injection. |
Obviously bigger is better. Turbos and 3.6s are cool too! But 10k could certainly buy a budget conscious fellow a very nice professionally built 200+ hp 3.0, core and all which would positively scream in a lighter midyear car...especially if they had the 7:31 gearing. It would certainly be a big improvement over a tired 2.7...much as a 3.4 would be over a 3.0
89 911,
Do you have more engine shots (before installing)? What heater duct are you using on the dist side, turbo? Who made your fuel preasure line? Regards, J.P. |
The fuel pressure gauge is there because I have an adjustable fuel pressure regulator. I need to bump up my pressure 6-8 lbs over stock to go with the MAF. It is easier then having to hook up a gauge all the time. Fits on the pressure fitting on the fuel rail and uses a glycerin filled gauge. The backdated ducts are just off an older car. The left side needed to be altered to make room for the distributer. Very tight fit in there. |
89 911,
What size fittings did you use for the fuel presure hose? Thanks, J.P. |
| All times are GMT -8. The time now is 01:23 PM. |
