BOBCOHEN's Avatar
Will These Wheels Fit My Car??????
I have a buddy that has a nice set of 18" wheels that he wants to sell to me for short money but i dont know if they will fit my 930? He had them on a 928 he owned and then on a 91 911. Does the bolt pattern match my car? and what would i need for spacers? or dont waste my time. Thanks
Old 06-20-2004, 12:48 PM
klaucke's Avatar
As far as I know, almost all Porsche 5-lug wheels (excepting 356's wide-five) take a 5x130 bolt pattern, which is basically unique to Porsche, so the bolt pattern is definately the same. If they fit a 1991 911 (964) I assume they should fit your 930. I'm not sure what size flares the 964's used, but I know turbo's have some pretty wide flares. What year is your 930? An expert will have to chime in here, but I would guess your 930 is at least as wide or wider than a 964 and that they will fit. The offset may determine if they will "fill" your wheel wells.
Old 06-20-2004, 12:57 PM
BOBCOHEN's Avatar
The car is a 88 (still for sale) and i do believe the 930 is much wider then the 964.
2006 H2
2000 Toyota Camry
1997 PORSCHE TT
2006 Harley Street Glide
2001 25' Baja Outlaw
2004 Artic Cat F7
2006 Artic Cat F6
2001 Yamaha Blaster
2002 SUZUKI LT 80's x 3 for my 3 little boys
Old 06-20-2004, 01:03 PM
BOBCOHEN's Avatar
ttt
2006 H2
2000 Toyota Camry
1997 PORSCHE TT
2004 Artic Cat F7
2006 Artic Cat F6
2001 Yamaha Blaster
Old 06-21-2004, 06:08 PM
maxnine11's Avatar
are the offsets marked anywhere on the wheels??
928s and 964s use wheels with a much higher offset number, so you might be up to some massive spacers on the rear to fill out the 930 fenderwells.
max
max
Old 06-21-2004, 06:13 PM
