3.2 Upper Engine Rebuild Questions
On a 3.2 with 101,000 miles using one quart Valvoline 20/50
every 800 miles or so, smoking on deacceleration just starting to need a valve guide job. Is there a difference in valve guides ? and what is the opinion in doing new rings while you are there ? Any things else that I need to check while the heads are off ? What about new valves ? the heads are getting redone. I only have so much money to play with, it is either put it all in the engine or.... just do what is necessary and go with exhaust, chip. This is a bone stock 89. The exhaust I am looking at with a chip would be $2,000.00( Fabspeed,SSI's), The base upper rebuild is $5,000.00 (Great shop, done right !) It is this or spend it all on the motor ? Thanks, Chuck |
Leave the rings alone unless you have a reason to replace them (like breaking them during removal of the jugs).
My opinion is that you are a ways off from needing to replace anything. One quart every 800 miles is within specs. I would start thinking about engine work when you get down to one quart every 500 miles or less.
Without disrespect, I tend to agree with Kurt V.
Something tells me there's a lot of money being spent on Porsches without them needing it, really! "The ennemy of good is perfect" ;) |
This is a case of I have the money NOW, I may not have it in a year or so when the problem gets worse.
Put it in the bank or buy something that will add value to your car. Fikse wheels New interior Even better yet -another p-car for the track. |
It's tough to do this stuff incrementally. |
| All times are GMT -8. The time now is 02:20 AM. |
