-   -   High Beam doesn't work....isn't bulb. what else to check? (http://forums.pelicanparts.com/porsche-911-technical-forum/168858-high-beam-doesnt-work-isnt-bulb-what-else-check.html)
IanW505 06-22-2004 08:44 AM
Like the topic says, drivers side high beam isn't working. Thought it was the bulb, which i replaced. Nothing still. What else should i check, relays, switches, wires, etc.?? i have H1's on a '84 targa. Many thanks!
-Ian
sfmlaw17 06-22-2004 08:50 AM
Have you tried the fuse? There are 4 fuses, 1 for each high and 1 for each low. Easy to burn just 1 out and not effect the others.
IanW505 06-22-2004 08:53 AM
I would, if i knew where the fuses were. They're the things right behind the bulb assembly?
no substitute 06-22-2004 09:13 AM
Front trunk (the only trunk) drivers side, plastic cover pops off. I'm assuming the Carreras have the same fuse box location as the SC.
IanW505 06-22-2004 09:17 AM
Yep, got it. The Number 1 fuse on the front most part is broken, which according to the plastic cover is for the left high beam. Duh. problem solved. It's a white fuse i think? what does that correspond to and do carerra's have spare fuses anywhere?
Thanks Sean and No Sub, appreciate the help!
jrdavid68 06-22-2004 09:47 AM
Do you happen to have the original tool kit? It came with a few spare fuses. Mine were tucked down in one of the pockets and I "stumbled" across them when going through the tool kit.
no substitute 06-22-2004 09:59 AM
I believe it goes white, red, blue--8, 16, 25, someone check me here. Fairly common Beetle fuses.
djmcmath 06-22-2004 10:01 AM
Available at your local VW dealership, perhaps? I've been wondering what I'd do if my fuses ever blew. ...
Dan
no substitute 06-22-2004 10:08 AM
Dan
I believe Pelican would have these, often come on a blister pack with all colors. maybe you can use something else to save on shipping. If you need them sooner, Bow-Wow if they're still in business, or the shop near Sea-Tac airport on the strip will have them, as well as some auto supply places.
klaucke 06-22-2004 10:15 AM
My local Autozone and Napa carry the fuses I need for the 911 and my bug.
sfmlaw17 06-22-2004 11:16 AM
Geez, you guys are fast. I take a long lunch and get back and the problem is completely solved. Happy to help out. I ordered a package of each size fuses from Pelican to keep on hand in case of these emergencies. You never know.
IanW505 06-22-2004 11:28 AM
Excellent idea Sean, i think i'll do that too and just keep them in the car. In the meantime, i'll run up to the local porsche dealer and grab the one i need. Like Sean said, you guys are awesome, thanks so much for the help.
These fuses just screw in and out? i've never seen a fuse with the metal strip exposed like this.
-Ian
steve911 06-22-2004 11:35 AM
Ian--
Its a tension fit, not a screw in. GENTLY pull back one of the ends and replace the fuse. Kinda like putting a battery into something. I'd recommend using some fine grit sand paper on the terminal ends to ensure good contacts.
djmcmath 06-22-2004 05:20 PM
Right -- tension fit. It has little spring-plate thingies (technical term) on either end. I've never seen anything like it before! :) I usually put a little electrical-silicon-grease on electrical stuff before putting it back together too, but that's just me.
Dan
PS -- I was actually thinking of Bow-Wow before Pelican. I wonder if there's a price difference between VW fuses and Porsche fuses? :)
IanW505 06-22-2004 08:10 PM
Problem solved, thanks to all that helped. Got me a bunch of fuses on Pelican too, 10 bucks for 30! woohoo.
-Ian
