wastintime's Avatar
Send a message via AIM to wastintime
downforce of carrera vs. turbo spoilers
Hey everyone,
I have the stock spoiler that came on my RSA, which is the carrera tail. It had been suggested that a very easy way to add more downforce would be to swap out the carrera rubber for the rubber from an early (pre-964) turbo tail. Does anyone happen to know the actual difference in downforce?
Thanks,
Andrew
Old 06-22-2004, 09:42 AM
Porsche published the differences and were once found in the Up-Fixin series published by PCA. Bill Verburg has the same graphs.
The Turbo style provides more downforce, but in either case the downforce generated is not enough to overcome the rear lift inherent in the car's body shape. There is still "net" lift. The difference is about 50 lbs of additonal downforce for the Turbo vs Carrera tail at 150 mph, or so....as I recall ( don't have those publications in front of me at the moment).
BTW....if you increase the downforce in the rear if you, how do you counter-balance the front? How do you intend to add more front downforce if you add a Turbo rear tail?
---Wil
Wil Ferch
85 Carrera ( gone, but not forgotten )
Old 06-22-2004, 10:02 AM
RUF opted for the Carrera tail on the yellowbird,according to RUF it offered enough downforce with less drag then the turbo version.This was a car capable of over 200 mph,safely,from what the testers said it was pretty stable.RUF had an underbody spoiler also which was a rubber lip similar to the 914.
my life begins at 150MPH
Old 06-22-2004, 10:15 AM
Hald's Avatar
Let's see if this is legible when reduced from >500KB ...
Mark
'77 Carrera 3.0
http://members.rennlist.com/hald
Old 06-22-2004, 12:56 PM
From Fig 2....if we assume "turbo" means early turbo that is much like the Carrera spoiler...and if we assume "3.3 Turbo" is the commonly-held view of the later high-sided turbo style....
...then the 50 lbs difference is about right at 150 mph, it seems...
---Wil
Wil Ferch
Old 06-22-2004, 02:10 PM
KobaltBlau's Avatar
which ain't much, in my opinion.
plus the carrera and turbo 3.0 tails look better than the turbo 3.3 tail, if you have to have a tail (IMHO). I'm really surprised the ducktail is that close to the turbo 3.0. looks like 20-25 pounds perhaps. drag might be a different story...
Mark, were there drag numbers or graphs from that same source?
TIA
Andy
Old 06-22-2004, 02:39 PM
Bill Verburg's Avatar
Groan, , a search of 'downforce and drag' might be educational
Bill Verburg
Old 06-22-2004, 02:52 PM
wastintime's Avatar
I understand that it's going to make more drag, but I'm not really as concerned with drag as I am getting as much downforce in the rear as possible without changing tails. I'm going to switch to the turbo rubber, I was just curious how much more downforce it actually generated.
I already kinda felt like the front needs splitters with just the carrera tail, so i'm sure the splitters will do their job with the turbo element as well.
-Andy
'67 912, '92 C2, and '93 RSA - all gone
Old 06-22-2004, 03:25 PM
KobaltBlau's Avatar
My apologies. I just asked about drag since we were already talking about lift. I did a search on your suggestion, lots of info. No need to rehash.
Andy
Old 06-22-2004, 03:44 PM
Nice groan Bill
Dean
911 SC turbo, 3.0L 930 motor, G50, 930 brakes, DTA EFI, 352 RWHP DynoDynamic dyno,
Old 06-22-2004, 03:46 PM
Hald's Avatar
Mark
'77 Carrera 3.0
Old 06-22-2004, 04:29 PM
Hi,
I was thinking about the turbo rubber on my Carrera spoiler, too, to get more downforce in the rear. I only wanted to change the rubber, not the body of the spoiler, but there are 2 things I do not know:
1. Does the turbo rubber fit with the same holes as the Carrera spoiler?
2. Is the higher downforce (50 lbs) of the turbo spoiler to much for the Carreras spoiler body (would the spoiler crack or would the engine lid get damaged?), because the backside of the turbo spoilerbody has an other shape?
But I dont see any problems with the balance, when the turbo spoiler is installed, because the factory sold the SCs with the turbo rear spoiler.
Thorsten
Old 06-22-2004, 04:48 PM
North Coast Cab's Avatar
Bruce Andersons book shows several 911's on the cover and many of them have the Carrera tail with an added plexiglass piece to extend them. I always wondered if anyone ran one of these and if so how they performed.
John
1985.5 944 GTS
Old 06-22-2004, 05:09 PM
Hald's Avatar
this may be a technicality, but, as I understand it, the various 911 spoilers we're talking about do not create "downforce". They "spoil" lift. The distinction being, if all lift were able to be removed by a spoiler, then the car would be no lighter, or heavier, than its static weight. A wing that exerts downforce, however, results in the car in motion actually being pushed on its suspension more than the weight of the car, alone.
Mark
'77 Carrera 3.0
Old 06-22-2004, 05:23 PM
}{arlequin's Avatar
Reading this made me laugh, mostly due to this classic: 911 rake front/rear
dave
1973,5: one two thweeee!
no.don't.stop.
Old 06-22-2004, 05:43 PM
wastintime's Avatar
mark,
these really are more wings than spoilers, just look at a carrera tail from the side, you can't help but notice it looks exactly like an aircraft wing with its flaps extended, that's why they use the lip extensions in Bruce Anderson's book, more drag, but much more downforce. The fact that depending upon the tail it isn't enough to completely counteract the lift the car generates doesn't mean it's simply spoiling the air rather than creating downforce. If you look at the graph, the 3.3 turbo tail compared to a car with no spoilers does almost negate the lift at speed.
-Andy
Old 06-23-2004, 03:06 AM
Hald's Avatar
I should know better than to try to add to a conversation on a subject about which I know nothing...
Mark
'77 Carrera 3.0
Old 06-23-2004, 03:43 AM
david914's Avatar
OK, while we're on the subject, how does the front chin spoiler function? Does it create a vacuum under the car by directing air around the car rather than under it, or ???
David Dryden
'86 911 Coupe
'05 BMW X5 4.4i
Old 06-23-2004, 09:21 AM
}{arlequin's Avatar
I think it just directs more air over the car than otherwise would be possible without it.
dave
no.don't.stop.
Old 06-23-2004, 09:24 AM
KobaltBlau's Avatar
It reduces the amount of air getting stuffed under the car.
Andy
Old 06-23-2004, 09:50 AM
