What is a tank screen
I am restoring a 74 fuel tank by completely removing the rubbercoating and recoating it as well as cleaning the inside and buying new parts. What is the tank screen that I see in the exploded view and what does it do. Is is a filter and should it be changed. Also what tool removes that large inset screw at the bottom to take it off.
Thanks.
79 SC unmolested 75 911 backdated RSR widebody 71 911T having fun skinny 63 356 outlaw frustrating purists 25 GTS |
i bought a new drainplug for the fuel tank on my 75. it came with a new screen attached to it. i didnt mess with it to see how it came off. but it pokes into the main body of the fuel tank from the smaller baffle tank inside. so i assume gravity takes the gas from the big tank, drains it thru the screen and lets the filtered gas sit inside the smaller baffled section. taking it off was easy, i went to a hardware store with my new drain plug and simply found a nut that fit. (at the time i didnt have any allens big enough). then i bought a bolt, and double nutted it, and simply cranked it off with my box wrench. did anything i just said make sense? if not pm me.
if i had to guess at the size of the allen, i would say 17 or 19 mm.
poof! gone |
Thanks vash,
From the looks of the plug and screen would you think that this is something I should replace after thirty years. It is was all working fine when I pulled the tank. I guess I'll will use your nut system and see what it looks like when get it out. Thanks for your help.
