changing plugs on 964 turbo with power steering
hi
i am in the middle of doing some service work to my car including a new set of spark plugs!!
the plug below the power steering pump looks as good as impossiible to change without removing the pump, if so whats the best way to remove the power steering pump and belt which will probably have to be removed aswell???
just so i dont have any more problems refitting other than the usual skinned wrists!
thanks!!!
Old 10-19-2006, 05:12 PM
pjv911's Avatar
Send a message via AIM to pjv911
Since it has no engine mounted oil cooler maybe its accessable from underneath ? I have the same engine but the p/s pump is removed. I believe the tin has an access hole from the bottom. Might be worth a look.
Kurt Williams
Never drive faster than your gaurdian angel can fly.
82 SC w/965S eng and G50 6:1 hp/w ratio
72 911t 2.6 twin plug and 72' 911t 57k orig 1 own miles
65/66 912 1 owner 76k orig
01' Aston Martin DB7 V12 Vantage Coupe 6spd
Old 10-19-2006, 05:40 PM
Insert Tag Line HERE.....
rattlsnak's Avatar
Most people drop the engine down a few inches...
Marc
Old 10-19-2006, 06:57 PM
resident samsquamch
sand_man's Avatar
Mine is a 930 so I have no worries of the power steering pump, but I remember this comprehensive thread from Rennlist with lot's of maintenance being done to a 965:
http://forums.rennlist.com/rennforums/showthread.php?t=94329&page=4&pp=15
Many guys actually remove the engine tin that runs along side the cam housing.
-jeff
Old 10-19-2006, 08:25 PM
resident samsquamch
sand_man's Avatar
Be sure to check page 5...
-jeff
Old 10-19-2006, 08:28 PM
hi
guys
what a nightmare to change that plug below the power steering pump!!
i found the only way to do this was to remove the rocker cover on the top of that side thus allowing me to get the spark plug key on at an angle!
good job these cars are great,if they werent nobody would want to buy them because of the hassle to work on some jobs on them!
thanks for your help!!
SP Autobahn www.spautobahn.co.uk
Porsche inspector for Peter Morgan UK
http://www.porscheinspections.com/
"92" 964 turbo,Modified and recently rebuilt using all ARP hardware..
Purpose built fuel controller set up to acheive perfect fuel curve on CIS inj.
Old 10-25-2006, 05:52 PM
remove the tin attached to the cam tower and go in from underneath. i use a swivel type 5/8" plug socket with a short extension, it's all one piece. snap-on has them in various lengths. all the right uppers are done that way.
206 637 4071
Old 10-25-2006, 06:32 PM
