-   -   CIS Cold Start easy fix (http://forums.pelicanparts.com/porsche-911-technical-forum/168943-cis-cold-start-easy-fix.html)
Guy Chiattello 06-22-2004 05:48 PM
I was beginning to have cold start problems with my 82SC and was sure I would be spending a considerable sum for a new WUR and Cold Start Valve. Before buying the pressure gages from Witney, to do the necessary pressure testing, I decided to add some fuel injector cleaner to my fuel tank which was about 3/4 full. Volia!! it did the trick. No more cold start problem. I suspect that the cold start valve was dirty and the injection cleaner took care of the problem.
Guy Chiattello
82SC Black Coupe
Paulporsche 06-22-2004 08:28 PM
Congratulations on your easy fix.
If only they were all that easy.
You may want to do a search. Many have recommended 2 tanks w/ Techron, followed by an oil change.
Paul
VincentVega 06-22-2004 09:49 PM
I want your luck! :)
