-   -   Distributor Advance Curve (http://forums.pelicanparts.com/porsche-911-technical-forum/169081-distributor-advance-curve.html)
B D 06-23-2004 10:46 AM
Does anyone have the information for the distrbutor advance curve for a 911L? Is it the same as other 2.0 130 HP 911's in 1968, did the Sporto have a slightly diffrent curve?
Thanks in advanceSmileWavy
B D 06-23-2004 01:18 PM
I know the specs for idle and at 6K RPM, I just need the in-between numbers. I am getting the distributor rebuilt and want to verify the specs of the curve with the rebuilders.
126coupe 06-23-2004 02:08 PM
I have my 2.0L Factory Manual out you need to get the # off the Distrib co i can post a pic for you. 6 different Dizzie #'s in the Manual
B D 06-23-2004 02:19 PM
OK here is the problem the distributor number I have is incorrect, the case is diffrent from the internals. I guess you just need the 911L dist. # though.
Here it is orginal dist # 0 231 169 001 from Bosh site. Thanks
126coupe 06-23-2004 02:28 PM
Here are the Dizzie specs for all 2.0L That # you posted is not in my manualhttp://forums.pelicanparts.com/uploa...1088029661.jpg http://forums.pelicanparts.com/uploa...1088029680.jpg http://forums.pelicanparts.com/uploa...1088029701.jpg
126coupe 06-23-2004 02:29 PM
those photos came out like crap, I'll try again later
911pcars 06-23-2004 02:31 PM
Some of these distributor curves were described in a thread here. It should be searcheable.
Sherwood
B D 06-23-2004 02:43 PM
Thanks Minkoff I think I got what I need for now. Better pictures would be great and appreciated by all.
