Car wobbles
My 95 993 wobbles over 100km/h. would a strut brace solve this?
Tks for any thoughts.
Marcelo
Old 06-23-2004, 08:19 AM
Friend of Warren
You don't have a problem a strut brace would fix. You either have a tire balance problem, wheel bearing problem, tie rod problem or loose lugnut problem. Possibly a front end alignment problem.
Kurt V
Old 06-23-2004, 08:21 AM
echrisconnor's Avatar
Could also be a bent wheel. Regardless, a strut brace will make NO difference for wobbling.
'76 911 Carrera 3.0
Old 06-23-2004, 08:31 AM
oneblueyedog's Avatar
Could also be worn out ball joints on the a-arms.
78SC coupe, Silver Metallic
Old 06-23-2004, 08:50 AM
The car has 20k miles and I suspect on bearings. I donīt hear the usual noise on old bearings but I feel as if there was no grease on them, like steel rubbing on steel.
I will check those things.
Tks for the info.
Old 06-23-2004, 10:58 AM
Did the alignment and guess what?
Everything is perfect now......tks for the advises.
Old 06-25-2004, 12:16 PM
