oil cooler
I'm thinking about getting a mocal kit for my 911. Would anyone recommend these kits, and if so which size cooler would you recommend for a 2.7. I might do some engine upgrades, so something with a little growing room would be good.
Old 06-18-2004, 11:03 AM
Ho Hum 74's Avatar
Yes, they are fine. You must be careful because the BAT instructions for installation of the thermostat and the Mocal ones are different. Call to speak with them 1st.
Also, if you get the big spoiler mount cooler you will need a new front spoiler as the cooler cannot fit behind the original valence. There are a few options but not all are 'cheap'.
Tristan
Old 06-18-2004, 11:07 AM
I am probably going to get the Mocal Oil cooler kit for my 911, but I was really wondering which oil cooler to get. They have several different sizes with different amount of rows. How many rows do I need for 2.7 that might be swapped someday, so i want some growing room?
Old 06-22-2004, 12:19 PM
VincentVega's Avatar
They offer 2 kits from what I recall. I installed the smaller kit on my SC and it works fine on the street. On the track, on a HOT day it's not enough though, at least for my SC.
The bracket fit nicely and the hoses were a nice fit as well. You can do a lot worse.
Old 06-22-2004, 12:25 PM
Bandwidth AbUser
Jim Richards's Avatar
BAT has a Mocal kit for the 911 that uses a 19-row cooler. I have been told that it's marginal for use on a 911. I'd recommend you go larger.
FYI, I used a Carerra cooler w/o fan and at the track I still can get fairly warm oil temps on my 73E (2.4L). I have a battery box in the way of air flow to the cooler, so that reduces its effectiveness.
Jim R.
Old 06-22-2004, 12:28 PM
Automotive Monomaniac
Emission's Avatar
Besides cost (or room), why wouldn't someone go with the larger unit? The engine can't run "too cold" as long as the thermostat is operating correctly - right?
2018 - Porsche 911 Carrera 7MT / 2018 - Porsche Macan 7DCT / 1993 - Cadillac Allante / 2023 - RAM TRX (on order)
Old 06-22-2004, 01:00 PM
KobaltBlau's Avatar
I would recommend the elephant racing "widemouth" carrera type cooler with ducting (ducting described in other threads), or a front-mount cooler for track use on that size motor. Between the two of those it depends on your priorities. Front mount is better at the track but requires a different bumper or at least a different valance, and is a bit more vulnerable.
I just put one of the elephant racing widemouth coolers in on my 3.0, and I definitely need to duct air to it for track work at higher ambient temps. I do believe that it will be sufficient once I add the ducting, however.
btw: if you are not tracking the car, the mocal might be just fine. my experiences are geared toward DEs.
Andy
Old 06-22-2004, 01:01 PM
I'm thinking about going with the Mocal 44 row cooler kit from BAT. Does anybody know how difficult it is to install a Mocal Kit. I also like the elephant racing products, but they're on the expensive side
Old 06-22-2004, 01:29 PM
Doug Steinel's Avatar
Wayne has a write up in the Pelican technical papers that shows how to install a Mocal cooler.
77 911, 3.0L
Old 06-22-2004, 02:38 PM
KobaltBlau's Avatar
They are worth it IMHO. are you going to track the car?
Andy
Old 06-22-2004, 03:00 PM
Well, thank you for the advice. I am only 18 years old and a college student, so I'm just trying to get a lot for my money.
1974 911 Coupe 2.7
1973 AMC Hornet X 360ci
1988 Toyota 4 Runner
1981 Chevy C-10 SWB
2009 Chevy Z71 DD
Old 06-22-2004, 03:33 PM
GettinHeadStuds's Avatar
Sell the bimmer...it wont get you much...but you'll be able to get the biggest dam oil cooler....
83 SC (gone) / 72 T (gone)
Old 06-22-2004, 03:51 PM
KobaltBlau's Avatar
I understand about the money, believe me. but:
Andy
Old 06-22-2004, 04:01 PM
KobaltBlau's Avatar
Philip, did you wear out your old user account?
Andy
Old 06-22-2004, 04:02 PM
IROC's Avatar
I installed the smaller Mocal unit (fender mount) on my car with a 6 inch Spal fan. Worked great with the 2.7 (never got above 180F on the street and 210F on the track). Now, with the 3.2, it struggles to keep it right at 180F on the street. Max temp I've seen (in Alabama summer heat) is about 185F on the street.
Mike
Mike
1976 Euro 911
3.2 w/10.3 compression & SSIs
22/29 torsions, 22/22 adjustable sways, Carrera brakes
Old 06-22-2004, 04:06 PM
Yeah, I reached 911 posts and retired it.
Old 06-22-2004, 04:37 PM
Well, I would sell the BMW. but then I would have to drive the 911 to college, and that would be a little to scary for me. I'd rather run to mileage up the BMW, and let it get the door dings instead of the 911. I'm probably going to go with the 44 row Mocal kit. It seems like it would be more than enough.
1974 911 Coupe 2.7
1981 Chevy C-10 SWB
2009 Chevy Z71 DD
Old 06-23-2004, 11:37 AM
KobaltBlau's Avatar
Andy
Old 06-25-2004, 11:44 AM
As of right now, I am not going to race my car. I haven't the funds or the time to do so. It is a possibility that I might in the future.
1974 911 Coupe 2.7
1981 Chevy C-10 SWB
2009 Chevy Z71 DD
Old 06-28-2004, 08:36 AM
Zeke's Avatar
Is this cooler going in the fender or up front?
I have been told that the Setrab cooler is a better unit, but you are not going to get a bolt in kit going that route. Avoid having the thermostat up front if that's the way the Mocal is designed. Seems to me that was the case on their setup for the 914 that I considered.
Old 06-28-2004, 08:47 AM
